Oil pan questions
Old Apr 11, 2015 | 09:13 PM
Pickupmanx2's Avatar
Pickupmanx2
Oil pan questions
Ok,,, so I have my 66 F100, Shrek, he has a tired 240 I6, that runs great, just smokes a tad,,, I've asked him to quit, but he hasn't even tried..
I came across a 302 out of a 74 Bronco, it has the funky oil pan, 2 sumps I think, do I need a different oil pan to put on before I drop it in Shrek?
Old May 17, 2015 | 02:57 PM
Pickupmanx2
Anyone?!! I think I am going to buy one from summit or someplace, the dipstick tube is loose and leaking on this one,,,
Old May 18, 2015 | 10:05 AM
sseebart's Avatar
sseebart
A photo might help . . .
Ultimately, it might just come down to test fitting. As long as the pan clears the crossmember and you can access the drain plug, it's hard to see why it wouldn't work.
~Steve
Old May 18, 2015 | 11:06 AM
daveengelson's Avatar
daveengelson
As Steve suggested probly best to measure for fit. My 65, with the 302, has the sump at the front which leave approx. 3" between pan and cross member and removing the pan can be difficult, imagine with a dual sump pan may require lifting the engine. Another source possibly ebay for around $50??
Old May 18, 2015 | 11:13 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
C6TZ-6675-D .. Oil Pan-Use with push-in type dipstick tube / Obsolete
1966/68 Bronco 289 / 1969/70 Bronco 302 / 1973/77 Bronco 302 // 1969/70 Econoline 302
D1TZ-6675-C .. Oil Pan-Use with screw-in type dipstick tube / Obsolete
1971/72 Bronco 302 / 1971/72 Econoline 302 / 1973 Econoline 302 before serial number R20,001.
There's no pics of these specific oil pans, but I know that the 302 oil pan used in 1975/78 Mustang II's have 2 sumps.
kens65fb
May 12, 2018 02:14 AM
tluns
Jan 6, 2018 12:58 PM
lm987
29
Aug 9, 2010 08:55 PM
Papa'sPride
Apr 24, 2008 08:13 PM
Firemudder
Apr 21, 2007 07:58 PM
