hub locking problems
Old Apr 11, 2015 | 12:37 PM
sudsmcduff's Avatar
sudsmcduff
was not able to turn driveshaft by hand, cleaned and greased hubs with guzzles page instructions. was ok for a few months but now still cant turn driveshaft. is this the point where i should buy warn hubs? do i need to check for vacuum leak? thanks. i do use 4x4 a handfull times a year.
Old Apr 11, 2015 | 03:09 PM
mueckster's Avatar
mueckster
Pop the ESOF hubs out and see if the driveshaft turns freely with them removed. If so, replacing them with manual lockers would be more cost effective. A vacuum leak would not cause hub engagement. Vacuum apples the hubs.
Old Apr 11, 2015 | 03:24 PM
sudsmcduff's Avatar
sudsmcduff
removed and pushed down on springs inside a few times. all is good now. i see riff raff has 2 kinds of warn hubs, do i need the premium warn hubs? or go with the cheaper, thanks
Old Apr 11, 2015 | 03:41 PM
M-S-G's Avatar
M-S-G
I replaced warn non-premium with MileMarker. Way better, all metal and $99 on amazon. Highly recommended.
Old Apr 12, 2015 | 12:04 AM
crop harvester's Avatar
crop harvester
Warn pemium's has always performed well on our several 4x4's.
Old Apr 12, 2015 | 10:45 AM
whitetmw's Avatar
whitetmw
Annual maintenance will keep the operational indefinitely. I do mine in July, that way they're ready for December.
Old Apr 12, 2015 | 07:34 PM
sudsmcduff's Avatar
sudsmcduff
I think my main issue is last year I had to drive in 3 feet of waves at pismo beach to go pick up a friend at the entrance. Used salt away when I got back but didn't get it all off. My rear brakes had issues dragging few months back
Old Apr 13, 2015 | 10:18 PM
M-S-G's Avatar
M-S-G
Ouch. Salt water.
Pro tip: take them out and soak overnight in your used motor oil bucket.
Old Apr 13, 2015 | 10:29 PM
sudsmcduff's Avatar
sudsmcduff
Originally Posted by M-S-G
Ouch. Salt water.
thanks for that, i will
strat875
Modular V8 (4.6L, 5.4L)
Dec 1, 2015 10:26 PM
mackstruck
Sep 5, 2011 10:10 AM
adam10
Apr 7, 2010 05:54 PM
RShaips
Dec 11, 2005 01:31 AM
sjankowski
Nov 16, 2005 03:23 AM
