faulty eatc unit
Old Apr 11, 2015 | 06:22 AM
marbleman67's Avatar
marbleman67
faulty eatc unit
So this morning when I started my truck ( 2005 f350 4x4 drw) the eatc failed to power up. I am aware of the parking light trick and yes it work. I'm wondering if anybody knows what causes the eatc to not power up. This has happened once or twice a year since my truck was new. Any advice will be greatly appreciated
Old Apr 11, 2015 | 07:33 AM
dannyboy950's Avatar
dannyboy950
So far as I know no one has discoverd exactly why it happens. Just the work around.
Old Apr 11, 2015 | 08:09 AM
69cj's Avatar
69cj
If it did it when new you should have had the unit replaced while under warranty. I told my dealer that it did it intermittantly and they installed a new one no questions asked.
Old Apr 11, 2015 | 08:31 AM
marbleman67
I did have it replaced while under warranty, only to have the problem return. I believe it is something other than the unit itself. I really think it has to do with the relay in the instrument cluster. Has any one else had the problem return after replacing the unit
Old Apr 11, 2015 | 09:07 AM
69cj's Avatar
69cj
Unusual, I never had a problem after replacement. Good luck. If the headlight trick isn't working then you probably have some other problem.
mohle
Nov 14, 2012 11:50 PM
Supercab
All Things Towing
19
Aug 9, 2012 07:05 AM
GuitarJesus
May 29, 2012 05:14 AM
SURBAN
Jul 10, 2011 01:41 PM
bigdually3
21
Apr 2, 2010 10:27 PM
