Sending unit blues
Old May 27, 2012 | 06:31 PM
GuitarJesus's Avatar
GuitarJesus
Sending unit blues
Ok so the sending unit on my new fuel pump gives me a bad reading on my rear tank. It's a used unit with 2 year warranty but the pumps both work and no more problems with tanks feeding each other. Can I just use the old sending unit? It seemed to give me a good reading. Or do the FoMoCo modules not unholy the sending unit?
Old May 27, 2012 | 06:45 PM
ncranchero's Avatar
ncranchero
Use your old sender if it functioned properly. I broke the wire @ the solder joint on the little circuit board, disassembled it, re-soldered it .......... good as new.
Old May 28, 2012 | 08:54 PM
diode_ee's Avatar
diode_ee
Not to try and threadjack your post, but is there any place to purchase just the circuit board for the fuel sender? I'm finding it impossible to find a entire sending unit that is compatible with my 1987 F250 7.5L carburated truck.
Old May 28, 2012 | 09:33 PM
GuitarJesus
Did you try Rockauto.com. ?
Old May 29, 2012 | 05:14 AM
ncranchero's Avatar
ncranchero
Not to try and threadjack your post, but is there any place to purchase just the circuit board for the fuel sender? I'm finding it impossible to find a entire sending unit that is compatible with my 1987 F250 7.5L carburted truck.
No, I've never seen a replacement source for the circuit boards.
hugger94
May 21, 2009 12:01 PM
redneckdieselmechanic
Aug 20, 2002 12:27 AM
