EGR Problems!
Old Apr 10, 2015 | 09:08 PM
jason90f150's Avatar
jason90f150
EGR Problems!
Hey everyone I just bought a early 95 f150 xl. It has the 4.9, 4x4, e4od. I noticed the speedometer and od were out and it shifted rough and found a bad fuse and that cured that. Then the CEL was on and I get code 332. maybe it was on the whole time. Anyway I checked the vacuum canister looked ok, sprayed cleaner on all of the hoses and propane, only found a leak to the FPR and replaced that. I then replaced the EGR. Same code again even after pulling the paperclip midway in the test and driving a few miles. Could the first catalytic converter be clogged? Is there a certain amount of exhaust that goes through the tube? Im going to pick up a hand held vacuum pump and check for leaks tomorrow. Is there a code for clogged cat? Hope Im not missing anything.
Old Apr 10, 2015 | 09:39 PM
Mike1's Avatar
Mike1
Try reading this and see if it helps. https://www.ford-trucks.com/forums/1109187-egr-valve-problem-solved-error-code-332-a.html
Old Apr 10, 2015 | 10:46 PM
jason90f150
Thanks. Ill replace all of the vacuum lines tomorrow.
Ford Breakdown
1983 - 2012 Ranger & B-Series
Jan 19, 2012 08:18 AM
f100guy
1997 - 2003 F150
Jan 17, 2009 09:37 AM
CM1
Jul 29, 2008 01:07 AM
brandon0011
1997 - 2003 F150
Feb 25, 2007 11:13 PM
champine
1997 - 2003 F150
15
Sep 18, 2006 09:14 PM
