Fuel tank sending unit
Old Apr 9, 2015 | 09:01 AM
264WSM's Avatar
264WSM
Seems all I can find is a replacement for a gasser. Is there a difference between the diesel and gas fuel tank sending unit?? (other than the pump - I can pull that off)
Old Apr 9, 2015 | 04:27 PM
Xyeniko's Avatar
Xyeniko
https://www.ford-trucks.com/forums/1...g-units-5.html
Old Apr 11, 2015 | 08:53 AM
264WSM's Avatar
264WSM
Thanks for the link, seems there is a difference.
Both of my metal tubes have broken loose from the plate that is the top of the sending unit. I tried JB Weld and that failed (& leaked). I could try brazing or welding them. Just afraid welding will burn thru the tubes and then I'll just suck air. Junk yard could be the only option.
Old Apr 11, 2015 | 09:48 AM
Chevy_Eater's Avatar
Chevy_Eater
It really helps if you put your truck info in your post or signature as replacement/repair options will change depending on the generation of truck you have.
Old Apr 12, 2015 | 05:44 PM
264WSM's Avatar
264WSM
'89 F -250. Rear tank. I have an extra capacity (36 or 38 gal) Spectra tank. Any OEM type sending unit will work, I'll just modify it to suck from the bottom.
Old Apr 13, 2015 | 01:01 AM
tecgod13's Avatar
tecgod13
Brazing or soldering your tubes should work. I'm a little surprised that JB weld didn't work. Maybe you didn't put a thick enough layer on.
Old Apr 13, 2015 | 06:07 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by 264WSM
1989 F250 aft axle fuel tank: Seems all I can find is a replacement for a gasser. Is there a difference between the diesel and gas fuel tank sending unit?? (other than the pump - I can pull that off)
Gas sending unit different than diesel. Plastic aft axle tank sender different than steel aft axle tank sender, wheelbase also makes a difference.
Old Apr 13, 2015 | 02:37 PM
madpogue's Avatar
madpogue
Are you having a problem with the sending unit (gauge), the float or the pickup?
Old Apr 14, 2015 | 06:52 PM
264WSM's Avatar
264WSM
Both pick up tubes are loose from the metal tank plate - this causes a leak when full, until 3/4 or 5/8 tank.
It is an extended cab but the rear tanks are the same as in strd cab.
Old Apr 14, 2015 | 07:45 PM
Xyeniko's Avatar
Xyeniko
you'd think an oil resistant gasket maker would work to stop the leak. you're refering to the metal tubes on top of the sending unit rotted out around the tubes so they're free from the plate?
Old Apr 14, 2015 | 08:12 PM
madpogue's Avatar
madpogue
So you need the showerheads, and/or repairs to the pickups. That's a LOT cheaper than the sending units. IIRC, the sending unit just attaches to the return pipe Are the leaks in the lines above the plates, or inside the tanks? I would think if it were inside the tank, they would just cause the fuel pump to draw air below that level. And if it were outside, it would leak all the time that fuel is flowing through it. Do you have it off the truck, can you post a pic?
Cab type has no bearing on the tanks. All (stock) rear tanks on the pickup trucks are the same, "officially" 18 gallons. Front tanks vary by BED size; short bed gets a 16-gallon tank, long bed gets a 19-gallon tank.
Old Apr 15, 2015 | 03:12 PM
NumberDummy
Take a look-see at these fuel tank applications from the 1980/89 truck parts catalog. 99 is a Styleside pickup.
Old Apr 15, 2015 | 03:45 PM
madpogue's Avatar
madpogue
^^^^ Oops, I was thinking OBS. Forum section phase shift.....
Old Jul 4, 2015 | 08:49 PM
264WSM's Avatar
264WSM
I got them brazed up and will be installing them this week. The truck is loosing prime now and I'm thinking it might be in the tank selector switch. I replaced the inj equalizing/return lines 3 months ago.
Old Jul 10, 2015 | 02:47 PM
264WSM's Avatar
264WSM
The brazing worked as I put 36 gal in the tank and no leaks.
As far as the loss of prime, I'm gonna try the return lines. It was my 88 that I did 3 months ago not the 89.
garydmundy
Jul 15, 2016 05:14 PM
elroy6468
May 13, 2015 04:23 PM
Piston Honda
29
Jan 28, 2014 03:47 PM
Jimfrey
Sep 4, 2006 02:37 PM
