My brother and I put a new timing chain in 351M and we tried to get it to idle by sound but it doesn't idle until the vacuum advance hits the thermostat housing! We've changed the timing in another 351M and did not have this happen. We didn't use the timing light yet but I guess we should have before I posted this. We lined up the timing chain right when we put it in.
Try rotating the crank until the rotor lines up with the #1 terminal on the dist cap (where you have it now), then pull the distributor and turn the rotor counter-clockwise about 45 degrees, and re-insert the distributor.
When everything lines up where it's supposed to?
When you lift the distributor, put a little pressure on the rotor in the direction you want it to move. When you feel it release from the drive gear, stop lifting and try to drop it into the next gear tooth. The oil pump drive will probably keep the distributor from dropping back down. Either you have to trust your move and turn the engine to re-engage the oil pump drive or you'll have to completely remove the distributor to move the oil pump shaft so the distributor will drop in on the tooth you need.
Hope this helps.
Greg
It's back-yard mechanics all the way, but you could just move all the plug wires back one terminal (one at a time so you don't get the order off...) and not have to pull the distributor... it really doesn't matter what tower it's pointing to as long as the order is correct. You'll have to rotate the distributor back enough to make the rotor line up with the correct tower again...
I love this guy....Good call. I seem to be the guy who buys your trucks and scratches my head when I try to repair them. No hard feeling man, I like your style.....Woody
No offense taken - Hey, that is why they tell you to allways replace the plug wires one at a time, right?... LOL.
Sorry, but I never got the point of being too **** about trying to worry aboutd exactly where the distributor was pointing when I stabbed it in - when it hit a gear right and the pump-drive lined up I stuck a fork in it and called it done - picked whatever tower it lined up with and set up the timing from there... I bet I've saved a couple of hours accumulated time over what all you folks that have to line it up exactly every time have spent!
That's what they make 'breaker' bars for. You get the distributor lined up correctly, drop it in until it just engages the cam then turn the engine slightly with the breaker bar until the distributor slides right down. Just remember to take the breaker bar off before you start the engine!
ah, but then you loose having the timing marks lined up...! (I have an excuse for everything! ) Also on a brand-new engine thats really tight I can get a little nervous that I'm going to strip something off trying to turn a motor over using the balancer bolt - the whole thing is really supposed to be held together more by the interference fit of the taper on the crank and balancer than by the bolt itself. I'm also leary of turning things any more than I have to before I fire it up for the initial run-in; I don't want to wipe the assembly lube and stuff off of the cam and lifters... (I do get **** in other areas, huh?)
I have seen a tool made for tuning a motor over that bolts on the front of the balancer using the pully mount holes - I average rebuilding a motor every 4 or 5 years, it's not something I do all the time, so I haven't invested in one. (Yes, I know, I probably should )I know I wouldn't have half as many qualms about turning it over with the bar if I did have one...
