carb problems 351w
Old Jul 25, 2003 | 09:54 PM
fencebuilder's Avatar
fencebuilder
carb problems 351w
i have an 81 f350 with a 351w, idles good in park but as soon as i put it in drive it idles roughly .... low and rough for about 2 seconds then extreemly high for about 1/2 second then back to low and so on ..... smooths out after im up to speed...
can anyone help me..?
Old Jul 26, 2003 | 12:32 AM
Ford_Six's Avatar
Ford_Six
carb problems 351w
When was the last tune-up on the truck?
Old Jul 26, 2003 | 01:15 AM
LxMan1's Avatar
LxMan1
carb problems 351w
Sounds like a vacuum leak somewhere.
Jimmy
Old Jul 26, 2003 | 04:17 AM
fencebuilder
carb problems 351w
put plugs in yesterday along with a new fuel line, filter, fresh oil & oil filter also, has recent cap and rotor. dont have timing light so didnt set timing, could this be the problem? in regards to vacuum leak , i have a soft brake petal , could vacuum be being lost thru bad brake booster and causing idle problems?
fencebuilder
Old Jul 26, 2003 | 11:39 AM
LxMan1's Avatar
LxMan1
carb problems 351w
It is possible if the diaphram has ruptured. You will usually hear it hissing in the cab when you push the brake pedal.
Jimmy
Old Jul 28, 2003 | 01:00 AM
Ford_Six's Avatar
Ford_Six
carb problems 351w
Usually a vac leak through the booster results in a hard pedal, so that can probably be ruled out. You may want to rebuild the carb and replace the base gasket. The rebuild kit for the Autolite/Motorcraft carbs is around $13, and the job itself is relatively easy. There very well may be some crud in the carb, possibly in the idle air bleed circuit.
econobox
26
Jan 4, 2013 11:51 PM
MarksA-C
Jul 6, 2011 02:25 PM
Ken Blythen
Oct 28, 2010 01:59 PM
jesse_h97
May 19, 2009 12:50 PM
nickh
Oct 21, 2007 07:04 PM
