Mazda trans?
Old Apr 7, 2015 | 07:34 PM
78sForever's Avatar
78sForever
Mazda trans?
maybe this has been asked before but has anyone installed a mazda trans out of a mid 900 truck into one of these?
Old Apr 7, 2015 | 08:09 PM
bkaul's Avatar
bkaul
Not sure how many people have done it, but I've seen a couple threads where it was at least discussed:
Ford Truck Enthusiasts Forums - Search Results
Old Apr 7, 2015 | 09:47 PM
HIO Silver's Avatar
HIO Silver
Here is a search where M5OD appears in the thread title: https://www.ford-trucks.com/forums/s...rchid=14792397
From Wikipedia, the free encyclopedia
The M5OD (Manual 5-speed with Over Drive) is a line of manual transmissions produced by Mazda and used in Mazda and Ford cars and trucks. Two variants, light-duty R1 and medium duty R2, are made. R1 transmissions have been used in the Ford Ranger, Explorer, Aerostar, and Bronco II. R2 versions have been used in the F-150, Econoline Van, full size Bronco, and the Cougar/Thunderbird with the supercharged V6. The M5OD ended production in December 2011, being last used in the 2011 Ford Ranger.
The M5OD is fully synchronized on all gears, including reverse. The synchronized reverse gear was one of the main features of the new units, to protect internal components from being damaged by inadvertent operation by the customer, and was protected by US Patent 4,757,726.[1] The transmission has an integral bellhousing, making the power plant stiffness high enough to avoid harmful resonance. The transmission uses a hydraulic clutch setup and has an internal slave cylinder."
M5OD-R1
1988–2011 Ford Ranger
1988–1990 Ford Bronco II
1988–1995 Ford Aerostar
1991–2000 Ford Explorer
M5OD-R1HD
1997–2002 Ford Explorer (4.0 L SOHC V6 engine)
2001–2011 Ford Ranger (4.0 L SOHC V6 engine)
M5OD-R2
1988–1996 Ford F-150 (4.9 L {300 ci} I6 and 5.0 L {302 ci} V8 engines)
1988–1996 Ford Bronco (4.9 L {300 ci} I6 and 5.0 L {302 ci} V8 engines)
1997–2008 Ford F-150 4.2 L V6 and 4.6 L V8 engines
2006–2011 Ford Ranger/Mazda BT-50 (2.5/3.0 L I4 common rail turbocharged diesel engines)
2007–2010 Ford Everest (2.5/3.0 L I4 common rail turbocharged diesel engines)
Old Apr 8, 2015 | 04:11 PM
78sForever's Avatar
78sForever
Ya I did a search before I posted and didn't come up with much. Hopefully something will crop up or ill press on and relay my progress on here. Thanks
Old Apr 8, 2015 | 05:50 PM
tndallas's Avatar
tndallas
Click on my username and look at some of my previous posts. I've got one that has several links to good info about the swap. Also if you do a Web search for f100 m5r2 you'll find a fordification post w the swap on a bumpside that is very helpful.
TimothyOnline
General Automotive Discussion
Nov 11, 2018 08:08 PM
Curated Content Editor
2019 - 2023 Ranger
Aug 19, 2017 12:08 AM
nollid172
Montana Chapter
Mar 9, 2012 06:52 AM
MM1281
5.0L Coyote
30
Oct 3, 2009 04:04 PM
tommyii77
Jul 19, 2009 10:30 AM
