idle fluctuations
Old Mar 18, 2002 | 05:14 PM
ACEMAN's Avatar
ACEMAN
Post idle fluctuations
F-150 4.9 at startup and for about eight minutes idle fluctuates until it heats up. Turn it off and try it again same results but not as severe. I have an idea that it could be plugs or something to do with the ignition system. Any ideas would be appreciated.
Old Mar 18, 2002 | 07:15 PM
Mulletwagon's Avatar
Mulletwagon
idle fluctuations
Possible perps are the engine coolant temp sensor, inlet air control (iac)valve, and EGR valve. The way to test the iac is to pull the connector off while idling. If the engine stalls immediately, it is probably bad. If the engine shudders and shakes and finally stalls, it is probably OK.
First order of business is to scrub out the throttle bore where it mates with the butterfly valve. Fords are famous for gunk in the bore causing idling problems.
Good Luck
Old Mar 18, 2002 | 07:28 PM
Mulletwagon
idle fluctuations
jr2000sd
Feb 27, 2015 10:40 PM
MrPettis23
Jun 19, 2013 08:42 AM
Nod
1983 - 2012 Ranger & B-Series
Aug 23, 2012 11:24 PM
jaynalbu
1997 - 2003 F150
Apr 23, 2009 01:13 PM
brianas
Modular V10 (6.8l)
15
May 25, 2005 04:26 PM
