Forgive me if I'm getting the terminology wrong.
The gear for the speedometer thats on the shaft, not the cable, in the case.
Can it be accessed without splitting the case?
Having a hard time finding information.
Plus had a hard time getting the part. I've been told Ford still makes the gear, part number F7TZ17285AA, $11. Got it on order, see if its the right one when it gets here.
T-50 bit required for the four bolts. When re-installing the rear extension housing just use some permatex ultra gray or equivalent for sealing (there's no gasket).
