Forum Members please help!
Old Feb 27, 2005 | 01:29 PM
MustangGT221's Avatar
MustangGT221
I am in need of assistance ASAP.
This is In regards to the cable operated speedometer on the 87-91 trucks (in transfer case). I am in a big hurry and I need the answer to this question. I have looked through all my manuals and cannot find the answer. I need to take the speedometer's plastic "ring gear" off the shaft that is inside my transfer case. It's not the gear most people replace which is on the end of the cable (the "pinion gear"). This one is inside the rear extension housing (where the driveshaft goes into the TC's shaft splines). I need to remove this gear from the shaft. Can anyone tell me how? I'd like to do it without breaking it or damaging it, but I'm not sure if that is possible. Also, how does it go back onto the shaft?
I appologize that this really isn't in the correct forum, but I'm in trouble and need a quick answer badly (I need to finish this in a few hours). It's not a great excuse but sometimes ya gotta do what ya gotta do .
Old Feb 27, 2005 | 03:25 PM
95X15's Avatar
95X15
88 manual says to remove output shaft housing from transfer case (either manual or elec shift) and lift or center output shaft; remove retaining clip for speedometer gear. Slide speeometer gear forward back into case and remove the ball from shaft using a magnet. Should then be able to remove speedometer gear from shaft.
Good luck.
Old Mar 2, 2005 | 07:55 AM
MustangGT221
Sorry I didn't get back quickly but thank you, the procedure is done thanks to your info.
