Shock length
Old Apr 6, 2015 | 12:25 PM
jake_c_19's Avatar
jake_c_19
Shock length
I am looking at putting a 2 inch lift on my 86 f150 2wd and need to know what my factory shock length is and what my new shock length should be. I am think a simple cost effective 2 inch lift with 2 inch coil spacers on the front and 2 inch blocks on the back I will probably replace the coils and leaf springs while I'm at it.
Old Apr 6, 2015 | 02:46 PM
Franklin2's Avatar
Franklin2
With 2 inch coil spacers you will be borderline trying to get it back in alignment. There was a guy on here the other day that was looking at a rough country 2.5 inch lift and it comes with the proper brackets and stuff so you can get it back in alignment.
All you have to do is take a jack, and jack up the frontend by the frame 2 inches, and then stand back and look at your front tires. You will see what I am talking about.
Here's the rough country kit. It does have shocks in the kit.
http://www.roughcountry.com/ford-sus...it-425-20.html
Old Apr 6, 2015 | 03:03 PM
jake_c_19's Avatar
jake_c_19
2.5in Suspension Lift Kit w/N2.0 Shocks for 80-96 Ford 4wd Bronco [425.20] | Rough Country Suspension Systems®
I looked at this lift kit and it is for a 4wd will it fit my 2wd?
Old Apr 6, 2015 | 03:28 PM
CountryBumkin's Avatar
CountryBumkin
Have you considered doing a 2" body lift instead of a 2" suspension lift? You'll get the same tire clearance and its a lot cheaper. Of course there are pros and cons to both methods.
Old Apr 6, 2015 | 07:17 PM
jake_c_19's Avatar
jake_c_19
I have considered it but am not sure if i could install by myself, and dont want to pay for an installation
Old Apr 7, 2015 | 05:11 AM
CountryBumkin
It's easier than a suspension lift. Just need a floor jack and some blocks of wood (and air tools really make it go fast). And no alignment needed afterwards.
Were you planning to do the suspension lift yourself? Were you going to replace the brake lines with longer lines? It's a lot of work either way.
Old Apr 9, 2015 | 03:50 PM
jake_c_19's Avatar
jake_c_19
I was planning on doing it myself. I didnt think i would need longer brake lines for the suspension lift do i need them for a body lift?
SMV
Nov 5, 2015 03:59 PM
mikerans
Feb 24, 2013 04:08 PM
Skaget2002
Dec 28, 2010 01:40 PM
KDS69420
1978 - 1996 Big Bronco
18
Jan 16, 2005 08:06 PM
fatfenders
May 22, 2004 09:05 PM
