95 f150 leveling kit question
Old Feb 24, 2013 | 01:39 PM
mikerans's Avatar
mikerans
hi i bought a leveling kit for my 95 f150, all it is is 2 inch coil spacers from daystar with the bolt extenders. my truck has an extreme rake, and i have 6 leafs on each side of my truck for hauling, i no that with the 2 inch lift it won't lift it a full 2 inches because of weight, so in addition to the spacers, could i fit in a f250 spring on each side to compensate? also, would i need new shocks? i no il need a alignment and most likely new camber bushings for it, i just want to no if putting 250 coils, 2 inch spacers, and maybe 2/3 inch longer shocks is a good i dea.
thanks!
mikerans's Avatar
mikerans
also, its 4x4
Old Feb 24, 2013 | 03:24 PM
mikerans's Avatar
mikerans
i no theres a LOT of threads out there with info on leveling trucks pre 97..but i haven't found any that combine f250 shocks AND 2inch spring spacers, all i want to no is if this would work, and give me a combined at least 3 inches of lift in the front to level out. and if i could just use my stock shocks or if i would have to get shocks that are part of a lift kit that are 2 inches bigger.
thanks!
Old Feb 24, 2013 | 04:08 PM
mikerans's Avatar
mikerans
Iv been doing more reading, and i found 4 inch lift coils, would just one of those on each side be better?? or i also found 2 inch lift coils, i could use those with coil spacers? keep in mind i dont exactly want a 4 inch lift, more like a 3 but im trying to compensate for the weight of the truck.
SMV
Nov 5, 2015 03:59 PM
jake_c_19
Apr 9, 2015 03:50 PM
Bsharp76
6.7L Power Stroke Diesel
Oct 22, 2013 08:13 PM
Skaget2002
Dec 28, 2010 01:40 PM
ford_racing_4_life
1983 - 2012 Ranger & B-Series
15
Jan 11, 2007 03:52 PM
