Let's Talk About Glow Plugs
Old Apr 5, 2015 | 12:07 PM
Walleye Hunter's Avatar
Walleye Hunter
Winter's over and my starting problems are behind me (for now). Seeing as how important glow plugs seem to be to starting these things when it gets cold I'd like to have a full understanding of them, how they work and make sure mine are 100% next year. If better than OEM I'd be fine with that too.
Here's my understanding of how they work so we don't have to rehash what is known.
1) No glow plug no cold start.
2) GP, GPR and UVCH typical offenders.
3) GP's run for about 2 minutes after key on.
4) Full bank of lit GP's eats about 100 amps.
5) Ford GP's are highly recommended.
6) Ford GPR's are inferior and other relays should be used.
My GPR went south and I got new one and installed it. My truck would start sometimes, not others and sometimes with heavy fuel smoke. When I jumped the GPR with my screwdriver I could tell it was bad by the way the tip of my screwdriver glowed during the jump.
My initial questions:
1) How hot do the GP's get? Do they actually glow? Do they get hot enough to light the fuel? Does the fuel spray directly on them?
2) Do the GP's remain lit after the engine starts? If so for how long?
3) What does IH sell for GP's for use in their T444E?
4) I have found some Bosch GP's for these engines, any reports on those?
That'll get me started.
Thanks,
Mark
Old Apr 5, 2015 | 12:37 PM
whitetmw's Avatar
whitetmw
That's about it
Any resistance in the circuit will affect the overall operation.
The On-Time is determined by the several sensors. The primary being the EOT. Glow Plugs will remain on a maximum of 120 Seconds. Cycling the Circuit as some suggest really does nothing unless you're waiting the 120 seconds.
Give or take, that's about right.
Anything other than OEM will give you problems. Maybe not the first year. But, thereafter its a crap shoot.
I wouldn't say "inferior". But, others like Stancore have better long lasting Solenoids.
The most probable reason the end of the screw drive is thinner thereby creating resistance.
Yes, the glow RED.
Fuel enters the cylinder Atomized. Allowing its combustion at a lower temperature. The heat, and compression of the cylinder both create an atmosphere which is conducent to combustion.
Up-to 120 Seconds. The Dash indicator turns off after only 6-12 Seconds.
Their branded units. Which, I assume are the same as Motorcraft.
See # 5 Above.
Thanks,
Mark
The most important thing is to have the MINIMUM resistance feeding the Glow Plugs. Which means: Connections, Solenoid Resistance, Clean Terminals and the like. The rest is reliant upon starter condition and compression.
Here are some notes:
a. Glow Plug ON time is dependent on oil temperature and altitude. The Glow Plug relay comes on between 1 and 120 sec. and does not come on at all if oil temp is above 131 F.
b. Verify that B+ is being supplied on the large BK/W wire going to the Glow Plug relay.
c. Install a voltmeter to the glow plug feed terminal (two brown wires or center terminal on the shunt).
d. Using a Bi-Directional Scan Tool and EOT PID’s, verify glow plug "on" time.
e. Turn key to run position, measure voltage ("on “time) (Dependent on oil temperature and altitude) Relay on time Spec. Measurement 1 to 120 seconds B +
f. Note: Wait to Start Lamp "on" time (1 -10 sec.) is independent from Glow Plug "on" time
g. Glow Plug Resistance
h. Remove both 9 pin connectors from valve covers • Measure each Glow Plug resistance to Bat. Ground. Measure engine harness resistance to relay. .1 to 2 ohms
i. Glow Plug Connector to relay 0 to 1 ohms
Old Apr 5, 2015 | 12:45 PM
River19's Avatar
River19
Excellent post, thanks for taking the time on that one.
Old Apr 5, 2015 | 01:03 PM
Walleye Hunter
Thanks for all that information. The only thing I don't understand is what is B+?
Old Apr 5, 2015 | 01:47 PM
clem1226's Avatar
clem1226
B+ is short hand Battery positive voltage.
AKA 12V from the battery.
Old Apr 5, 2015 | 01:51 PM
Tugly's Avatar
Tugly
B+ = Battery Voltage.
If you are getting a hot screwdriver while shorting an energized GPR, it sounds like your GPR is not so energized as you thought.
Old Apr 5, 2015 | 02:04 PM
Walleye Hunter
Yep, that told me that the relay was not working at that time. Next time I tried it I only got a little spark when I jumped it and that told me that the relay was working that time. Now she works, now she don't.
Old Apr 5, 2015 | 03:06 PM
DieselDenny's Avatar
DieselDenny
Excellent reply Tom lets go flying!!!!
Old Apr 5, 2015 | 04:28 PM
Walleye Hunter
I need to go flying. Bird gets annual inspection next week. Hadn't been up since August. Pulled it out Friday to see if it would start and it did. Sure is nice to have something with no battery drain when it's not turned on.
Old Apr 5, 2015 | 04:31 PM
LAMADMAN's Avatar
LAMADMAN
I did know that the glow plugs stayed on longer than the wait to start light because my gpr failed last year and I had a friend turn the key on while I was metering the relay. But what the heck does the light tell you to wait for then? Fuel pressure??
Also I don't have the LED mod. and I know I don't wait a full two minutes before starting. is this a bad thing? Should we be waiting for a full glow plug cycle before trying to crank when its cold? Could it do damage?
Old Apr 5, 2015 | 05:08 PM
Walleye Hunter
Apparently there is no damage to glow plugs from starting while they are still glowing. Good question on the value of that ten second wait to start light. That is what made me ask if the glow plugs actually ignite the fuel.
Old Apr 5, 2015 | 07:02 PM
Glowplugger's Avatar
Glowplugger
Hey Walleye! I just swapped out my glowplugs and did a full writeup with pics in my build in my sig. Might be fun for a read. You can laugh at all my mistakes and skip those parts. They're not necessary for good glow plug workmanship anyway lol!
Old Apr 5, 2015 | 07:57 PM
Tugly's Avatar
Tugly
The WTS light is nothing more than a reminder. "Oh yeah, this isn't my gasser car."
Old Apr 5, 2015 | 08:28 PM
whitetmw's Avatar
whitetmw
Glow Plug On Time vs EOT
Old Apr 5, 2015 | 11:09 PM
Glowplugger
Wow, so at 120 degrees outside theyre still on for 22 seconds or so!
Never woulda thought it, but that's good to know.
