I have a 1993 f250 the truck cranks right over but won't start or it will buck and fire for a few seconds then die again the cap and roter are clean the ignition control has been replaced and the coil has been replaced and the fuel pump kicks right on like it should with the normal loud wine noise it should make any ideas on what could be wrong?
There are no codes and the filter is also new yesterday it would start and run for about a min and then just shut off again and it just kept getting worse from there I'll try cycling the key tho and see what happens thanks
Vaccum is good so is the IAC I need to see what I'm getting for fuel pressure cuz it starts if you put gas/starting fluid down the intake so I think its a bad fuel pump not sure yet tho
