04 expolrer ABS codes
Old Apr 4, 2015 | 05:42 PM
James Whitaker's Avatar
James Whitaker
I am receiving 3 ABS codes C1155, C1145 and B1676. I am assuming the ABS sensor is bad for both right front and left front and need to be replaced, but dont know how to fix B1676. It says "Battery Pack Voltage Out Of Range" I tested the battery and i am receiving 12.4 volts what else can i do to fix this?
Old Apr 4, 2015 | 10:04 PM
shorod's Avatar
shorod
Is the 12.4 V measured with the engine running or the engine off?
There's a diagnostic procedure for this code in the factory service manual. If you'd like a PDF of the procedure, provide me with your e-mail address and I'll send the PDF to you.
-Rod
jawdoc
Feb 23, 2016 04:29 PM
tjc47
Feb 6, 2014 12:22 PM
zuikoman
1997 - 2003 F150
13
Dec 12, 2004 07:35 PM
mjmarchitto
Aug 26, 2004 05:46 PM
my289
Feb 24, 2002 11:32 AM
