Sponsored by: Auxito
ABS Codes on ODBII?
Old Dec 8, 2004 | 03:12 PM
zuikoman's Avatar
zuikoman
ABS Codes on OBD-II?
I got a code reader and I get no MIL codes when I scan the truck even though the ABS light is on all the time. I know I have seen ABS test sockets under the hood on Ford (post 96) vehicles... Is this not covered by the OBD-II and do I need something else to get ABS codes? Like one of those metal test keys that short out pins on the connector?
This is on a 2001 F-150.
Old Dec 8, 2004 | 06:31 PM
wgotthardt's Avatar
wgotthardt
ABS codes are NOT covered by OBD-II scans. I can all but guarantee it's your rear wheel sensor located on top of the differential. it takes about five minutes to R&R (one bolt). Part is about $12 through a retail parts store, and about twice that at the dealer. Replace it, and your light will go out, no codes to delete. Good luck.
Cheers, Wm.
Old Dec 8, 2004 | 09:07 PM
Racerguy's Avatar
Racerguy
Most cheaper code readers aren't capable of reading anything but OBD II codes.
Better scan tools can read ABS, GEM etc codes as well.
Old Dec 9, 2004 | 07:50 AM
fixer1's Avatar
fixer1
That ABS light will stay on even after the part is replaced. You need an abs code reader to reset the ABS light on F150'S from 2000 and up as I understand the system. Ford told me that they would do it but I have to make an appointment and pay $59.95 for the service. My service shop just bought a system that will take care of the problem and they will reset it for free. autozone does not have an ABS-AIRBAG code reader.
Old Dec 9, 2004 | 11:45 AM
wgotthardt's Avatar
wgotthardt
That's incorrect...I've replaced mine ('00), and a neighbor's ('01). On both trucks the light has stayed off after replacing the rear sensor.
Cheers, Wm.
Old Dec 9, 2004 | 01:07 PM
KevinM's Avatar
KevinM
Even if it does, most of the time you just have to disconnect the battery. Sure the CU will have to relearn the engine, but that doesn't take long!
Old Dec 9, 2004 | 01:57 PM
zuikoman's Avatar
zuikoman
I saw on TV sometime them using a metal key that shorts out a couple pins on the test connector to put it into blink mode where the ABS light will blink 3 times, pause, then 4 times for code 34 (for example) and go through that cycle a few times a few times at startup.
I don't remember what kind of vehicle it was. Does Ford have the same deal? I could just replace the diff sensor but I'd like to make sure its not a wheel speed sensor first.
Old Dec 9, 2004 | 09:22 PM
Racerguy's Avatar
Racerguy
On a system with just Rear Wheel ABS you don't need any tools to get codes. If it has 4WABS you need a scan tool.
Old Dec 9, 2004 | 09:47 PM
bosshoss's Avatar
bosshoss
I just did a repair on a 99 f-150 2 wheel drive with RABS. I just removed the front kick pnl. Look for a conector that has a red wire on one side, and a black wire with a orange tracer on the other. Unplug the connection. Now take a wire and ground the black/orange connector to ground for about 2 seconds. Your abs light should start to flash a two digit code.
Dave P
Old Dec 10, 2004 | 10:53 AM
zuikoman's Avatar
zuikoman
Interesting. I assumed I had 4WABS but maybe not. It is a 2001 F-150 XLT 2WD w/Limited Slip diff.
Would this just have the RABS? So there are no sensors in this system besides the diff sensor?
Old Dec 11, 2004 | 04:28 PM
fixer1's Avatar
fixer1
Yes my book says only with 4wheel abs is there a need to reset with code reader. I forgot to mention that. Sorry.
Old Dec 11, 2004 | 07:58 PM
wgotthardt's Avatar
wgotthardt
Again, both my truck and my neighbors truck are 4-wheel ABS, and in both cases the light went out and has stayed off after replacing the rear sensor. There was no need to reset any codes.
In the time this thread has drawn on, the part could have been replaced 100X's over. ;-)
Cheers, Wm.
Old Dec 12, 2004 | 07:31 PM
low's Avatar
low
The easiest way to check if you have 4wabs or rabs is to see if you have wires going to the front wheels, in addition to the brake lines. If there are only brake lines, you have rabs only. Then you have to do the rutine mentioned above, grounding the wire in the right kick panel. If you see wires, you have front wheel speed sensors. 4wabs, you need a OBD2 scan tool to check the code. 95% of the time it is the rear wheel speed sensor on the top of the rear differential.
Old Dec 12, 2004 | 07:35 PM
F150'89's Avatar
F150'89
That only works on 1995 and older GM cars and trucks for the CEL.
