ABS Codes
Old Aug 26, 2004 | 07:41 AM
mjmarchitto's Avatar
mjmarchitto
Question ABS Codes
Thanks, this info is very helpful. I read how to get the ABS codes, seems fairly simple, however, where do I find a definition of the codes?
Old Aug 26, 2004 | 12:10 PM
SpeedracerGF's Avatar
SpeedracerGF
code reading
If you have a repair manual, the codes are listed . Haynes or Chilton repair books can be bought at any Autozone, Pepboys , O` Reilly`s or any auto part store . Auto zone will read the code for you for free, then tell you what the problem is. Just tell them you have a check engine light on (even if you don`t ). If you have the code I can e-mail it too you also !
Old Aug 26, 2004 | 04:22 PM
mjmarchitto
Check engine is different from ABS. Autozone adn others read CHECK ENGINE but they do not read ABS, I tried.
Old Aug 26, 2004 | 05:46 PM
SpeedracerGF
What codes are you refering too? & where are you reading them from ? Abs is pretty easy to work with. Could be a bad relay or bad senors in the front wheels?
