3.o blues
Old Apr 3, 2015 | 08:46 AM
dspencer40's Avatar
dspencer40
Angry 3.o blues
Need some help here. 2002 ranger edge 3.0 5spd. Truck idles perfect, but when you get rolling and higer rpms feels like the engine is missing. loos of power and shakes. I replaced the usual, plugs and wire's, seemed to help for a bit but came back. I cannot get any info on the scanner and have checked all the fuses. I am thinking coil pack but don't understand why it idles perfect and only misses under acceleration. No check engine light on. Any ideas from those whom are much smarter than I am?
Old Apr 3, 2015 | 10:00 PM
wtroger's Avatar
wtroger
When an engine is put under load it increases the the resistance on the plugs. If there is a weak plug(s), bad wire(s), bad or cracked coil pack then it will miss.
Old Apr 4, 2015 | 08:59 AM
Tennesseepowerstroke's Avatar
I am guessing but I would say a bad coil pack or it could be the PCM.
Old Apr 4, 2015 | 10:40 AM
Conanski's Avatar
Conanski
Not being able to get any codes from the PCM is a bad sign, does your scanner work with other vehicles? You could have a blown fuse on the DTC connector(it's often on the same circuit as the cigarette lighter) or you could have a PCM problem.
Old Mar 15, 2017 | 05:27 AM
miami592's Avatar
miami592
When was the last time the fuel filter was changed? If it is nearly clogged it will give that exact scenario.
Old Mar 15, 2017 | 06:02 PM
Kruse's Avatar
Kruse
Throw a vacuum gauge on it and make sure you don't have a restricted catalytic converter.
donaldm
Jan 9, 2011 08:20 AM
Kijutsu
1997 - 2003 F150
Apr 6, 2009 07:27 PM
smsmunoz
Mar 15, 2009 06:26 PM
PersiusOne
1997 - 2003 F150
Nov 24, 2008 07:19 PM
TennesseeGuy
Modular V8 (4.6L, 5.4L)
Dec 29, 2005 12:15 PM
