Sponsored by: Real Truck
Steering slop AFTER box replacement
Old Apr 3, 2015 | 01:15 AM
'02strokerpilot's Avatar
'02strokerpilot
I put a good quality reman steering box in my '02 diesel 2 weeks ago. Fixed 90% of the slop but there is still a small amount hanging around. The tires wander when I hit a bump such as a manhole. The tie rods and ball joints appear to be solid from what the mechanic shops have said (I took it to two different places to examine the linkage). Now I spoke with a friend of mine and he suggested the steering shaft u-joints could be loose? I didn't notice anything when I removed the shaft while installing the gearbox but wasn't looking for other issues at the time either. Is this a common problem for the 7.3's? I have 35" tires but they aren't exactly gigantic or oversized for the components that control them...if I were to have an issue how would I go abt discovering which shaft needs replaced? I heard that you can't just get the joint like on the driveline?? Oh and the tires are wearing perfect, no issues except the wander on camber changes in the road and miscelaneous bumps.
List of things I've replaced to give you all a little I sight:
Sway bar bushings, front shocks, ball joints, front hubs, steering box, drag link. I'm running out of stuff to replace haha!!!
Alex
Old Apr 3, 2015 | 04:18 AM
Yahiko's Avatar
Yahiko
Re check the ball joints.
Then have a look at the steering wheel mounts and make
sure that is all tight. Last I don't see an alignment in you list.
Don't forget larger tires amplify any short comings.
Sean
Old Apr 3, 2015 | 06:31 AM
Tom's Avatar
Tom
You want to inspect the linkage with the front wheels on the ground. Have a friend sit in the truck and turn the wheel lightly back and forth with the engine off. Look at the steering gear(not a box!) while this is happening and see if the play is in the gear. Next look at your linkage. Is there any slop in your joints?
Old Apr 3, 2015 | 08:24 AM
ultrasks700's Avatar
ultrasks700
Sean
Sean, I have a similar issue, I replaced the steering box and still have a small amount of play, where are the wheel mounts you are speaking of?
Old Apr 3, 2015 | 01:18 PM
Yahiko's Avatar
Yahiko
You want to have a look inside the cab where the column mounts to the framework.
Also do what Tom said and see if you can find it that way also.
Sean
big ole ford
Jan 30, 2019 08:59 AM
roboto
18
Jul 3, 2017 07:52 PM
Ed1934
Nov 26, 2016 04:55 AM
fordkid16
Aug 21, 2010 09:30 PM
jeffdoerr
Apr 22, 2007 06:30 PM
