Oil & Lubrication
MaxLife
Old Jul 25, 2003 | 04:56 PM
dtpatt2's Avatar
dtpatt2
MaxLife
Been using Valv. MaxLife in me truck, 112k miles. Should I continue using it or is it ok to switch to a Chevron or morotcraft brand? I hear that the additives they put in it swells the seals. I be ok?
Old Jul 25, 2003 | 04:57 PM
dtpatt2's Avatar
dtpatt2
MaxLife
BTW, I only used it for the last 2 oil changes...Just to see if it made a diff. I also don't have any leaks, etc.
Old Jul 25, 2003 | 05:57 PM
seldont's Avatar
seldont
MaxLife
I was usning Maxlife in my 5.4 at around 85,000 for just a couple of changes. Hoped it would help the piston slap a little. It did not and I changed to Motorcraft 5w30. Still no change in piston slap but I now have over 105,000 and have no other issues either. I think the Motorcraft is pretty good oil for $1.33 at Wally World.
Old Jul 25, 2003 | 09:08 PM
jrs_big_ford_f150's Avatar
jrs_big_ford_f150
MaxLife
I'd hate to sound stupid, but what is piston slap?
Old Jul 27, 2003 | 06:07 PM
mrit's Avatar
mrit
MaxLife
You dont sound stupid, just asking something you dont know. Its when the piston kinda flops around in the cylinder. Like when there is alot of wear on the piston or clyinder walls. That is what ruined the stock engine in my Bronco II.
Old Jul 28, 2003 | 12:28 AM
Scooter29's Avatar
Scooter29
MaxLife
Hey there guys! Just a tid-bit more info. The next time you do an oil change, you may want to consider using Lucas Additive. I've got 181k miles on my 351W and no oil consumption, smoke on start-up and the engine purrs.... I like to pass on some stuff.. Talk with you guys later....
Old Jul 28, 2003 | 06:49 PM
seldont's Avatar
seldont
MaxLife
I have not looked at the board for a few days but the 97 and up 5.4 engined in the F-150 have a history of piston slap which is supposed to be caused by the pistons not fitting in the cylinder bore til it is up to temperature. More prevelant in colder weather. Mine has a case of it as well and during cold weather it is very noticeable. Has not gotten any worse in the last 30,000 miles or so.
Old Jul 28, 2003 | 11:08 PM
jrs_big_ford_f150
MaxLife
Ok, one more question, does piston slap have a specific sound or no? I thinks it might have a sort of clunking noise?
Old Jul 29, 2003 | 12:11 AM
mrit's Avatar
mrit
MaxLife
With my old engine it was a sharp smack type sound, I not great at descibing though.
Old Jul 29, 2003 | 03:55 AM
Scooter29's Avatar
Scooter29
MaxLife
Hi everyone. I did find out a bit of info. Ford uses the same piston on a few engines. Some are installed in 180 degree position, since some engines need the valve reliefs that are cut into them at the machine shop. There is a tolerance that Ford seems to be able to live with, since the slap is minimal. Use one piston for many engines cut's cost for them and bigger paychecks for the stockholders! I've got to get me some stock! Talk with you guys later....
Old Jul 29, 2003 | 01:01 PM
jrs_big_ford_f150
MaxLife
Thanks for all the info guys.
kd0axs
Oct 15, 2011 08:03 PM
94MustangGT
15
Jul 5, 2011 08:31 AM
aztec12
Oil & Lubrication
Mar 1, 2007 12:32 AM
Dustin_86
Oil & Lubrication
Jan 6, 2004 12:33 AM
BigMattXXL
Oil & Lubrication
Mar 19, 2003 09:22 AM
