lower ball joint
Old Apr 2, 2015 | 04:24 PM
tsoza86's Avatar
tsoza86
lower ball joint
So im getting ready to do the lower ball joint on my 99 expedition. Any tricks to make it easier. Im having it towed to my work so ill have it on a lift and air tools. the thing just cracked first time ive seen one do that
Old Apr 2, 2015 | 09:21 PM
Hamfisted's Avatar
Hamfisted
In a '99 I'd replace the whole lower control-arm/ball joint assembly together. It doesn't cost much more for the control-arm with a new ball joint already installed, than buying just a ball joint and going to the trouble of pressing out the old and pressing in the new. Then you still have worn out lower control-arm bushings to deal with. Takes less of your time to replace the whole assembly too. The replacement Moog ball joints are greasable too.
-Mike
Moog Lower Control Arms at Rock Auto
Old Apr 3, 2015 | 12:12 AM
Skauber's Avatar
Skauber
Yep, that's the approach I'll be taking on my '05 as well, just replace the whole assembly with new bushings and all from Moog, then it will likely last as long as the truck itself if you grease it at every oil change or so.
lbrowne
Jun 16, 2011 10:13 PM
Jimmygunz3
Aug 21, 2009 07:04 AM
joeltwise
1997 - 2003 F150
Jun 21, 2009 09:37 PM
crashed13
Feb 23, 2006 02:28 AM
MitchPeters
Jul 7, 2004 09:45 AM
