engine oil
Old Apr 2, 2015 | 01:51 PM
gdoug219's Avatar
gdoug219
engine oil
I have a 2014 3.7 liter f150 stx. Any recommended oils people run that are known for durability and are trusted? I don't tow much other than my dirt bike.
Old Apr 2, 2015 | 02:02 PM
PrinceValium's Avatar
PrinceValium
Welcome to the forum.
I run Motorcraft oil since it is a synthetic blend and honestly have no intention of using anything else. How can you not trust an oil that is recommended by the manufacturer?
Old Apr 2, 2015 | 02:06 PM
Robbgt's Avatar
Robbgt
Another vote for this. My local walmart sells it too at a reasonable price.
Old Apr 2, 2015 | 02:43 PM
Beechkid's Avatar
Beechkid
MC semi for me also...............
Old Apr 2, 2015 | 02:47 PM
fire240's Avatar
fire240
I run motorcraft synthetic in mine. If I cant get that then I will run mobil 1 synthetic.
Old Apr 2, 2015 | 04:25 PM
Turbo Dog's Avatar
Turbo Dog
I'm using Royal Purple HPS in my 5.0. I am sending in samples for analysis and it can last longer than 12K miles at each change interval so far. HPS has extra anti wear additives (zinc & phosphorus) that aren't in most or all over the counter oils. It can possibly poison a catalyst over time so don't use it if you are subject to regular emissions testing. In that case just use the regular HP.
HPS - High Performance Street Motor Oil | Royal Purple
Old Apr 2, 2015 | 05:50 PM
tseekins's Avatar
tseekins
Veteran: Coast Guard
The normal MC oil and MC filter for me in all of my Fords.
Old Apr 2, 2015 | 07:01 PM
GuyGene's Avatar
GuyGene
Even though MotorCraft oil is synthetic blend, it's great. No matter what though, use MotorCraft filter! I'm crazy. I use full synthetic. I figure I'll give'er the best blood I can running through her veins and other pipes. Wha' the _______, hey a high dollar truck, a bit more for synthetic, I'm gonna do it.
Old Apr 2, 2015 | 09:59 PM
bdlesch's Avatar
bdlesch
I run Amsoil in all my vehicles. 5w-30 and their filter in my EB. I have used their oil for over 30 years and never had a problem. My '93 F-150 has over 375,000 miles on it. I find it well worth the money.
Old Apr 3, 2015 | 07:39 AM
MikeJ65's Avatar
MikeJ65
I use Mobil 1 in everything I own. Normally I run to the oil life indicator, but on the F-150 I will put on maybe 6-8K/yr and just change annually.
Old Apr 3, 2015 | 09:20 AM
Izzy351's Avatar
Izzy351
LOL... Ask 10 people about oil, get 11 answers. Can't beat MC, but any properly spec'ed oil in the correct grade will do the job nicely if changed at the proper interval. The EcoBoost is a little more finicky because of being a direct injected engine however.
You can go with extended OCIs if you monitor by sending samples to a lab and run high-quality syns. I knew guys running almost 20k on oil with bypass filtering and good syn with lots of additives in their PowerStokes. I think doing that on these engines is overkill though. Those engines held 15-16 quarts where these hold 6-8 quarts. That's a lot of trouble for a gallon or two of oil. Easier just to change it and be done IMHO.
Old Apr 3, 2015 | 04:38 PM
eriebasin's Avatar
eriebasin
I go to a mechanic I've had for years; he's very honest and they have all the latest technology; road force balancers, ASE mechanics, the latest computer diagnostics, etc. You get assigned a specific mechanic who always works on your vehicle. They have done nothing but oil changes and tire rotations on this truck thus far (Ford did the first 2 however as they were free with the purchase). Nonetheless, I use Motorcraft filter and Royal Purple Synthetic (I ask for the MC filter special but they carry Royal Purple in stock). Of course the dealer will do any warrantee work should i ever need any; I purchased the extended warrantee.
Old Apr 4, 2015 | 06:06 PM
maytag906's Avatar
maytag906
Pennzoil 5W30 synthetic blend in my 2011 5.0
Old Apr 4, 2015 | 06:40 PM
bigdaddyII's Avatar
bigdaddyII
I bring it to the dealer while under warranty, they use 5w20 Motorcraft with Motorcraft filter. wgen extended warranty is up it will get the same product in the form of a driveway oil change.
Old Apr 5, 2015 | 01:27 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
I use any any name-brand 5w20 that is on sale, (CASTROL, VALVOLINE, MOTORCRAFT & others) and change it every 5000 km or 3 months. Never got excited about synthetic, never had any issues with "plain" oil and I keep my trucks around 5 or 6 years.
Kept in touch with my truck buyers who followed this same regimen and they are still going strong 10 years later so why pay more?
