Flathead fan issues
Old Apr 2, 2015 | 06:31 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Your fan and generator/WP belts should be 3/4" wide, not 5/8"
Old Apr 2, 2015 | 08:22 PM
DocRoche's Avatar
DocRoche
Would that be the same for a 1950 F2? Im trying to find that in the book.
Old Apr 2, 2015 | 08:41 PM
ALBUQ F-1's Avatar
ALBUQ F-1
All the same 48 - 52 for V8s
It's on p 488 of the Parts CD
Old Apr 2, 2015 | 08:58 PM
DocRoche's Avatar
DocRoche
Got it, thank you
Old Apr 4, 2015 | 02:10 PM
DocRoche's Avatar
DocRoche
So if it calls for a 3/4 belt but they done seem to be made anymore do i just swap the pulleys to 5/8 where its needed?
Old Apr 4, 2015 | 02:53 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Lots of places sell them. Where are you seeing that they are 5/8"?
A quick Google search using the p/n's above found this for the gen/WP
Ford Fan & Generator Belt with Molded Ford Script - 7RA-8620-C - C&G Ford Parts
For some reason all the fan belts are under 21C-8577-A
Fan Belt | Dennis Carpenter Ford Restoration Parts
NAPA also has the fan belt, but shows a 5/8 for the gen/WP belt for some reason:
NAPA AUTO PARTS
My engine doesn't use these wide belts, I'm just going by the book. Is there any chance your engine is out of something else?
Old Apr 4, 2015 | 02:55 PM
harleymsn's Avatar
harleymsn
NAPA- 2526366 or 25-09330
Gates- 20A0935
Goodyear- 28373
Carquest- TR26366
Old Apr 4, 2015 | 03:04 PM
DocRoche's Avatar
DocRoche
I say 5/8 because all the new altanators are 3/8 & 5/8. My fan pulley is wider than the other pulley. I can't find anything besides those 2 sizes. There is not a 3/4 option. I know I need to research it more but I appreciate your knowledge.
Old Apr 4, 2015 | 03:16 PM
harleymsn's Avatar
harleymsn
Doc, the TR26366 I mentioned above is actually a 3/4" gates belt. Rockauto and carquest sells this belt and I would assume that any auto parts store that sells gates belts can get it for you. I know that I got my belts from NAPA, I'll have to go look at the truck and see if I can see the numbers on it.
1948 FORD F2 3.9L 239 cubic inch V8 Belt Drive : Belt Auto Parts
mlandrum51F1
Dec 6, 2025 01:21 PM
bulldogcountry1
Jan 22, 2018 06:28 PM
mOROTBREATH
Aug 29, 2010 09:37 PM
Tims47tonner
1947 and Older Ford Trucks
Sep 17, 2007 10:16 PM
1978fordf250
Aug 27, 2004 06:59 AM
