53 fan blade needed
Old Jan 14, 2013 | 07:33 PM
mlandrum51F1's Avatar
mlandrum51F1
53 fan blade needed
Hey fellers,
Got my 51 frame done, and the '53 block just about rebuilt, and just realized I don't have a fan blade, and I can't seem to find one at all the usual places (macs, speedway, lmc, obsolete...). Seems the '48 to '51' fan blades are different part numbers, but they look identical to me. (8 bolts). The '53 fan mount/pulley just seem simpler than the '51. Any ideas where I could find one? Thanks!
Progress to date: https://plus.google.com/photos/10578...73722546693585
Mark
Old Jan 14, 2013 | 09:50 PM
jmadsen's Avatar
jmadsen
for a flathead v8 I assume? ive got some extra fanblade assemblies for flatheads from different years. mostly of a 6 blade type if thats what you need?
Josh
Old Jan 14, 2013 | 11:29 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Does your 53 have 2 narrow belts? The parts CD shows it is the exact same fan (4 or 5 blades) as 48-52, with a different hub.
Old Jan 15, 2013 | 06:46 AM
jmadsen's Avatar
jmadsen
ive also got a narrow pully 3 blade fan and hub too. its only about 14.5" diameter on the fan blades. figured that might have been off a merc??
the fan blades dont bolt on though, looks like a fixed assembly.
Ill look through the collection tonight when i get home to see whats there.
Old Jan 15, 2013 | 07:26 PM
mlandrum51F1
Since I don't have one, I only have some diagrams (classicautoparts.com shows an illustration of the 48-51 assembly) but all the images I have found (google images of 53 flathead engines) show a 4 blade fan. And yes, its a Flathead V-8. I forget there is any other kind of engine! :-) I have attached a pic of the 'assembly', all ready for its whirling brother. Thanks for any leads guys and gals. Mark
Old Jan 15, 2013 | 07:36 PM
mlandrum51F1
It is the 'wide' (5/8") belts.
Old Jan 15, 2013 | 07:42 PM
ALBUQ F-1's Avatar
ALBUQ F-1
My understanding is that '53 Truck engines used the same type of large hub as 48-52 Trucks, but with a narrow-belt sheave. The car fans from early '50's-on had three (four on Merc) blade fans with a sealed cartridge ball bearing, like below. That is what I'm using and have had no cooling issues (with clean engine, shroud, deflectors, etc).
Old Jan 16, 2013 | 12:15 PM
jmadsen's Avatar
jmadsen
Ive got a few of the 6 blade fans with the eight bolt holes to attach.
but seeing your picture I'm not sure how the other blades attach.
seems the 4 blade fans only have 4 bolts?
here is a picture of a 6blade fan and assembly as well as a 4 blade setup, this four blade fan is riveted to the hub. (sorry for the bad pictures, dark and no flash)
I was browsing Ebay and there a few different ones on there, not sure exactly what you need though. Good Luck finding it.
Josh
Also looks like your fan is alot farther away from the pulley than both of these that I took pictures of?
Old Jan 20, 2013 | 09:35 PM
mlandrum51F1
Josh, is the 6 blade (3rd picture) 3 1/8" diameter from center to center of the bolts? Those are bolts holding it on, not rivets it appears. Thanks. Mark
Old Jan 21, 2013 | 05:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
No 6 blade fan listed in the truck parts catalog, only 4 & 5 blade fans.
TFAA-8600-A .. 4 Blade Fan-no hub ~ 18.5" diameter / 8 mounting holes.
Applications: 1948/53 239.
B7Q-8600-C .. 5 Blade Fan-Extra Cooling ~ 18.5" diameter / 8 mounting holes.
Applications: 1948/53 239 & 1957/63 F700/900 302/332 (Lincoln derived Y blocks).
Originally Posted by ALBUQ F-1
The car fans from the early 50's-on had three (four on merc) blade fans with a sealed cartridge ball bearing.
0BA-8602-B .. 5 Blade Fan, Hub & Bracket Assy-Extra Cooling / 1950/53 Ford 239 Passenger Cars.
EAB-8602-A .. 3 Blade Fan, Hub & Bracket Assy / 1950/53 Ford 239 Passenger Cars with 3 M/T & 3 M/T O/D.
EAB-8602-B .. 3 Blade Fan, Hub & Bracket Assy / 1951/53 239 Ford Passenger Cars with Ford-O-Matic.
Dunno what Merc had, no 1949/59 Merc parts catalog, but would assume it would be the same. I owned a '53 Merc with O/D...52 years ago.
Old Jan 21, 2013 | 09:05 AM
jmadsen's Avatar
jmadsen
yes the 6 blade fan has the eight bolts holding it on. and they are 3&1/8" apart.
Old Dec 5, 2025 | 09:27 AM
Smokey1959's Avatar
Smokey1959
1st Gear
Josh
do you still have any fan blades? i have a 50 ford v8 flathead 8 bolt mount. Thanks Mark
Old Dec 6, 2025 | 01:21 PM
330pbr's Avatar
330pbr
i have a 4 blade fan 8 mounting bolts with a single wide belt pulley
johnfin1
Aug 29, 2016 07:19 PM
medctr1
May 11, 2016 12:26 AM
Gertie-The '49 F2
Oct 5, 2015 07:40 PM
john fin
Oct 16, 2011 06:50 AM
