Help!! 5.8 351w
Old Apr 2, 2015 | 11:22 AM
1988F250351w's Avatar
1988F250351w
Help!! 5.8 351w
Hi guys I have a 1988 F250 with the 351w auto trans 3/4 ton rear wheel drive. My engine is being very moody sometimes it's hard to start but than sometimes it's not it drives great gets up to speed great for being a 3/4 runs great when at a stop light in drive with brake applied but it does not like being in reverse it just wants to die like its out of gas and has occasional hard start but very rarely does it happen just concerned because yesterday it was in reverse stalled started back up with a slight stumble backed it up put it in park proceeded to surge and went back to normal Rpm's I took to my mechanic today to pull codes but it didn't have anything on it. But he said my Throttle cable was sticking on him and it wouldn't respond Could it just be there's slack in my cable? And it's causing it to act up? I just recently did Gas tank sending unit fuel lines fuel filter plugs wires and cap oil change with filter new battery and cables Starting solenoid Pcv valve New map sensor Cleaned up IAC and new Air cleaner. Thanks in advance for opinions on this
Old Apr 11, 2015 | 02:17 PM
85e150's Avatar
85e150
Fix the cable and reevaluate.
Old Apr 12, 2015 | 10:39 PM
Jon Seng's Avatar
Jon Seng
I have some of the same issues try the cheap things first like the fuel regulator, fuel filter, and it could be a few other things but lemme know if any of that works.
parker_shelton
Jun 1, 2016 03:21 PM
dien4me
Jan 12, 2014 03:06 PM
ihuntelk
Apr 4, 2008 02:47 PM
shupingj
Feb 26, 2006 07:08 PM
jaja
1978 - 1996 Big Bronco
27
Aug 23, 2005 12:16 PM
