leveling kit issues
Old Apr 2, 2015 | 09:54 AM
2014denimstreetglide's Avatar
leveling kit issues
I purchased a 3.5" front and 2" rear leveling kit for my 2004 f150 4x4. I was getting some work done and my mechanic said there is no way this kit will fit my truck without changing the spindles because of the angle..will a different kit work say 2" or 2.5" front level spacers..also read that the leveling kits are blowing out ball joints and cv boots on the half axles..any help would b great or idea how I can get my truck higher with newer model spindles possibly from an Fx4 model or something..thanks
Old Apr 2, 2015 | 06:30 PM
The Oldtimer's Avatar
The Oldtimer
My 04 FX4 has a 2" leveling kit (spacers) and it works just fine...I opted for an aftermarket alignment kit to allow for any issues with alignment...not one single problem.
Old Apr 2, 2015 | 08:59 PM
steve(ill)'s Avatar
steve(ill)
as you raise the truck up, the angle of the axle shaft down to the wheel/ tire gets worse (sharper angle). That is a fact of life. There have been guys that go up to 4 inches, but like you said, that can take its toll on ball joints and CV joints. There is no good way to get by this. You just have to live with shorter life (possibly) on parts. Alignment is another problem and has nothing to do with the axle angle.
Old Apr 2, 2015 | 09:01 PM
steve(ill)'s Avatar
steve(ill)
you may be able to find aftermarket spindles to RAISE an inch. I have seen LOWER units advertised..normally for 2 wheel drive. Factory FORD parts are all the same.
Old Apr 3, 2015 | 06:57 PM
The Oldtimer
If the truck is lifted, the axle angle will affect the the camber...the camber will change enough to require an alignment, and the factory camber bolts may be close to their limits of adjustability. I replaced the factory adjusters with aftermarket ones that address the potential problem.
Ostie
2009 - 2014 F150
May 28, 2013 12:49 AM
04Fx4F150
2004 - 2008 F150
Mar 21, 2012 03:38 PM
bigseadaddy
Apr 13, 2011 09:50 PM
jjsniper32
Mar 17, 2010 09:44 AM
fordman19762003
2004 - 2008 F150
Jan 26, 2009 07:44 PM
