need an expert opinion
Old Apr 1, 2015 | 09:38 PM
fordboy97's Avatar
fordboy97
Went to a local transmission shop today to get a quote for a rebuild on my AOD. He said $1200 for a rebuild with a 6,000 mile or 6 month warranty. Or if I take it out myself and bring it to them he said it would be $800 with a 90 day warranty.
Should I try to save some money and remove/install it myself or let them do it for a better warranty? I've never had a transmission rebuilt but I did help my buddy install the trans in his '99 z71 4x4 auto
Old Apr 1, 2015 | 09:56 PM
6ohdslbilder's Avatar
6ohdslbilder
Having rebuilt several hundred of these the price isn't to bad, but that warranty offered sucks..
Old Apr 1, 2015 | 10:17 PM
'89F2urd's Avatar
'89F2urd
I cant testify as to how good those prices are, I don't mess with automagics.
however, its absolutely worth the savings you've indicated. it should take about 4 hours of steady work for the DIY'er to get the trans out. maybe a little more if bolts need to be cut from the crossmemnber.
either way, youre paying yourself ~100 an hour to remove the trans at that rate. well worth it.
Old Apr 1, 2015 | 10:44 PM
fordboy97's Avatar
fordboy97
So we have one vote for me doing the removal/installation. I think the $400 savings would be nice but I agree with 6ohdslbilder that the 90 day warranty sucks.
He said that it would be better for him to do all the work since the aod's are picky about adjustments or something like that.
Old Apr 1, 2015 | 10:53 PM
'89F2urd's Avatar
'89F2urd
Hmmm I don't like to admit this, but i was wrong. 400 includes the install too.....might want to just shop around and see what kind of other quotes you get for labor and warranty. That labor really is cheap, but spending a few hundred extra could go a long way with warranty.
Old Apr 2, 2015 | 03:17 AM
krooser's Avatar
krooser
The longer warranty on the $1200.00 deal is probably offered since the shop is doing the work and he has control over the whole job.
Old Apr 2, 2015 | 06:35 AM
fordboy97's Avatar
fordboy97
This is correct.
Old Apr 2, 2015 | 06:40 AM
fordboy97's Avatar
fordboy97
Another thing to, this is a pretty reputable shop that has been in business for many years. So I am gonna trust their work and see how it goes.
Just trying to decide if I should do the removal/installation because he said that AOD's are picky about adjustments (I assume at the TV cable) so it would be better if he did the all the work.
Old Apr 2, 2015 | 07:22 AM
WoodBoss's Avatar
WoodBoss
tranny
That is a very good price. Let him do it all. Remember installed he will have to supply quite a few quarts of tranny fluid and somehow flush all the metal from the cooling system. You may want to consider a new transmission cooler and or radiator. Anything that saw the tranny fluid has to be replaced or cleaned and inspected or it won't hold up.
Old Apr 2, 2015 | 10:20 PM
fordboy97's Avatar
fordboy97
He told me if I wanted a shift kit then bring it up there with me and he'd put it in for me. I'm gonna get the transgo AOD HP.
Old Apr 2, 2015 | 11:00 PM
Slomoe's Avatar
Slomoe
Wood boss is correct on cleaning the system. Dust from the clutches and metal chips will accumulate in the bottom of the radiator's trans cooling tank and then recirculating back into your trans. Next point is the shop cleanliness. Look around - do they have a clean room for assembly? Do they clean all the parts? or is it a dirty dusty wind blown open door build area and a parts swap shop.
I use to wipe out Mopar 727 trans behind a SS/A drag car. Ammco did the rebuilds. One day a professional pointed out the cleanliness issue. Next time I installed a B&M built one along with new oil cooler and lines. That was the last tranny needed.
Old Apr 2, 2015 | 11:12 PM
fordboy97's Avatar
fordboy97
Thanks for the advice on that. I've never heard of that but I have now. So replacement of the trans cooler would be best?
DidieX
Jan 29, 2019 09:55 AM
SoarX
Mar 11, 2016 05:38 AM
wastingas
Dec 20, 2012 11:30 AM
stinson 108-1
May 9, 2012 12:31 PM
nhill2090
May 7, 2010 05:06 PM
