Rough Idle - New Guy Here!
Old Apr 6, 2015 | 05:09 PM
  #76
96F250SD's Avatar
96F250SD
Flywheel is stationary... the... clurch itself moves side to side... it DEFINITELY sounds like a galled bearing now thay the cover is off... so that means new assbly right?
Old Apr 6, 2015 | 05:50 PM
  #77
madpogue's Avatar
madpogue
That movement (if you're talking about rotation) is actually the rear half ("mass") of the flywheel along with the clutch moving. Yeah, sounds like it's time to put a fork (no pun intended) in it, it's done.
Old Apr 6, 2015 | 05:56 PM
  #78
96F250SD's Avatar
96F250SD
More Information for LUK 07154
More Information for LUK LFW140
This all I need? I know it's not a south Bend but it's all stock and I'm not going to hop it up ANY time soon. Just exhaust and intake Once I get this done.
Old Apr 6, 2015 | 07:15 PM
  #79
farmert's Avatar
farmert
Those links could be for the IDI 7.3. It says 93-95, although the Stroke didn't come out until the mid 94 year, when the stopped the IDIs. If it is for an IDI, it will not fit the stroke. I look for a listing for a 96-97, then there would be no doubt it would fit.
Old Apr 6, 2015 | 07:24 PM
  #80
96F250SD's Avatar
96F250SD
How's this? I think the reason why it says that is because I'm looking at solid flywheel and clutch setups not dual-mass.
More Information for LUK 07226
Old Apr 6, 2015 | 07:46 PM
  #81
madpogue's Avatar
madpogue
^^^^ That listing also shows up for 1996, so it should fit our generation of PSD.
Old Apr 6, 2015 | 07:52 PM
  #82
96F250SD's Avatar
96F250SD
I'ma order it soon then...
Old Apr 6, 2015 | 10:06 PM
  #83
95_Dually's Avatar
95_Dually
Sorry to hear that's the problem, but now you know what is needed.
Old Apr 7, 2015 | 05:44 AM
  #84
96F250SD's Avatar
96F250SD
True... it sucks but it beats injectors or a new motor... right? After I get this fixed I'll do intake/exhaust to get it to breathe better... then drive the hell outta it!
Old Apr 8, 2015 | 05:30 AM
  #85
96F250SD's Avatar
96F250SD
Well I ordered the combination of luk clutch and flywheel kit. Also ordered a new slave and master cylinder... dropped it off at the shop today and hope to have it back next week...
Old Apr 8, 2015 | 08:25 PM
  #86
95_Dually's Avatar
95_Dually
That's awesome. You'll like it a lot.
Old Apr 8, 2015 | 08:28 PM
  #87
96F250SD's Avatar
96F250SD
I hope so!! Didn't really plan on spending about 800-1000 whwn it'd all said and done but I can't wait... after this it's oil flush take care of the leaks and drive!
Old Apr 16, 2015 | 02:55 AM
  #88
95_Dually's Avatar
95_Dually
Looking for an update on your clutch.
Old Apr 16, 2015 | 09:02 AM
  #89
96F250SD's Avatar
96F250SD
Haven't installed it yet... shop I go to is really booked hope to by first of next week or middle.
Old Apr 24, 2015 | 08:44 AM
  #90
96F250SD's Avatar
96F250SD
Update
Uptade, and it's done!! I won't go pick it up until later tonight but they called and said it's done. Will report back later with updates.
