Flareside Cap Mounting
Old Mar 31, 2015 | 10:28 PM
matador's Avatar
matador
I've finally found a cap that will fit my 1995 Flareside! I think it's for a Chevrolet, but the length is right, and the width is close, too. It's an older-style Leer that has the flat bracket on the sides (runners, if you will).
Does anybody have tips for mounting a cap to a Flareside? I'm assuming that the best way is L-Brackets that bolt into where the cargo tie-downs are located.
If anybody has ideas, though, they would be a huge help!
Thanks!
Old Apr 1, 2015 | 06:13 PM
matador's Avatar
matador
Nobody owns a Flareside with a cap?
No wonder it took this long!
Any ideas other than L-Brackets?
Old Apr 1, 2015 | 06:29 PM
MtTheJeffro's Avatar
MtTheJeffro
I had one about 10 years ago. Cap was held on by brackets that mounted to the inside of the bed. The brackets looked similar to half of a door hinge. The "hinge pins" were long bolts that threaded into L brackets that held the cap down
Old Apr 1, 2015 | 07:06 PM
*2fords*'s Avatar
*2fords*
Mine is screwed down thru the top of the bed rails. It was already like that when my Dad bought the truck.
Old Apr 2, 2015 | 03:32 AM
cjben's Avatar
cjben
I don't have a cap,but my flareside had a fiberglass bed cover(still has,but I never use it) when I bought it,and it uses this same kind of bracket.
Smoking Joe
Feb 11, 2019 09:54 PM
lowbed dud
All Things Towing
Jan 3, 2013 12:40 PM
Bruker
1983 - 2012 Ranger & B-Series
Feb 13, 2012 06:32 PM
Hummah Zach
2004 - 2008 F150
Apr 23, 2009 08:41 PM
spoon059
Mar 4, 2003 10:05 PM
