69 with a 91
Old Mar 31, 2015 | 09:47 PM
69issofine's Avatar
69issofine
69 with a 91
i was given a 69 f-250 flatbed for free just had to go get it,the only two problems i have had was no tranny and the engine is a straight six 300 out of a 91. they took the old tranny out because it wouldn't shift and decided it was a bad tranny so they scrapped the tranny and then lost intersest,they were nice enough to buy a new heavy duty clutch but never installed, the only thing wrong with the old clutch was the pilot brg was bad i replaced that and got a 4 spd manual from pull and save for 55 bucks and it works then i found out there is no spot for a fuel pump so i had to buy a electric. they had put the old carb and exhaust on but couldn't figure out the carb linkage that's all fixed now now just the blower fan that died and the truck overheats after a few minutes and i want to upgrade the alternator to one out of a tarus. i changed the thermostat and the water pump and the radiator has two outlets on the bottom one side is blocked off and a hose is going to the passenger side on top and bottom.what a pain. i have a rebuilt 1 bbl carb if anyone wants it. i was thinking about putting a 360 back in it. i think that was the original.
Old Apr 1, 2015 | 10:31 PM
orich's Avatar
orich
If you go back to a 360 you'll be lucky to get 11 mpg where as the 300 will or should get around 16+- depends how you drive it..
A lot of issues with the valve seats burning out from nonleaded gas with the FE engines
if made before 1972. Later engines have harden seats. The heads have a casting letters od D2TZ to D4TZ these heads are on the 72-1976 last yr for the FE engine
Most shops charge $650-$750 just to rebuilt & install harden seats.
Orich
Old Apr 2, 2015 | 08:05 PM
tsoza86's Avatar
tsoza86
I would keep the 300 those are great engines and just put a 5 speed in it. I had a 92 with 5 speed and 300 great engines.
"Otis" f-100
Mar 9, 2012 01:58 PM
danger-ranger93
Aug 2, 2011 11:37 PM
jonn5335
Oct 3, 2010 05:02 AM
Fomoco_7
Oct 12, 2005 02:39 PM
twuck
24
Sep 19, 2003 11:29 AM
