What Torque Converter?
Old Mar 31, 2015 | 03:52 PM
Schuyles's Avatar
Schuyles
Hey everybody.
I am putting a '79 351m and the c6 that came with it into my '56 F100. It will connect to a 9" from a '69 f100 with 3.25 gears. I am trying to keep the price down on the engine, so am doing minimal upgrades. I just want to get it going and maybe later on I will switch to a different motor or go through this one more.
My brother rebuilt the transmission to stock form. I am putting on an Edelbrock aluminum intake and new Edlebrock carb. I'm planning on buying all the necessary cables and brackets from Lokar to hook it all up.
I am only building this truck as a cruiser. I just want to be able to make a little noise, not be totally slow off the line at a red light, and be able to drive it on the hwy 3 hrs or so at a time.
In this situation, do I just buy a torque converter from a parts house that is a direct replacement for the '79 truck? Would I benefit from a "good" or upgraded torque converter?
I don't even know where to start...
Thanks!
Old Mar 31, 2015 | 03:55 PM
JPMallory's Avatar
JPMallory
What cam are you running?
Old Mar 31, 2015 | 03:59 PM
Schuyles's Avatar
Schuyles
I am tempted to upgrade the cam and timing (a lot of discussion on the "boat anchor" 351m says upgraded cam, timing gears, intake and carb will "wake it up") but for now, was going to just use the factory cam. I am not planning on rebuilding the motor, it ran well enough when I pulled it from the '79. I was just putting on the intake and carb for now.
The reason I am even looking at a new torque converter is somehow the old one got left outside and has been filled with water for like 2 years...
Old Mar 31, 2015 | 04:10 PM
JPMallory's Avatar
JPMallory
I am not an expert by any means. But, it doesn't sound like you'll need anything besides the factory torque converter. If at some point you start doing more upgrades to the motor, you may need to change it.
Old Mar 31, 2015 | 04:27 PM
Schuyles's Avatar
Schuyles
I appreciate the input! I am trying to do some reading about it, and I am leaning toward the factory converter as well. It seems like power and torque of the motor is the main factor...so I guess if an intake and carb changed the torque of the motor..maybe you would need a different Torque Converter...but I doubt my intake and carb will change too much?
Need to learn more
Old Apr 1, 2015 | 08:17 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
You might get better info from the 335 Engine Forum 335 Series- 5.8/351M, 6.6/400, 351 Cleveland - Ford Truck Enthusiasts Forums
Old Apr 1, 2015 | 08:24 AM
Schuyles's Avatar
Schuyles
Good point Thanks!
Old Apr 1, 2015 | 04:38 PM
drptop70ss's Avatar
drptop70ss
stock cam + 3:25 gears = stock converter. No need for anything else.
Old Apr 1, 2015 | 04:44 PM
Schuyles's Avatar
Schuyles
Thank you!
Schuyles
Apr 4, 2015 08:24 AM
RangerHaywood
Apr 24, 2010 10:56 AM
70T351W
Nov 1, 2006 08:18 PM
FordPower78351M
May 5, 2003 11:53 PM
werkdatool
19
Aug 17, 2002 09:50 PM
