Sponsored by: Real Truck
Slow cranking when hot
Old Apr 19, 2015 | 06:37 AM
DavidB's Avatar
DavidB
The test results that you posted do not sound reasonable, which causes me to wonder if you did the tests correctly.
Old Apr 19, 2015 | 06:54 AM
08f3506.8's Avatar
08f3506.8
I removed the fuel pump relay. Put one lead of meter to the positive battery post, and the other lead to the other end of the cable at the starter. Set meter to min/max and cranked the starter. Then did the same with the ground
Old Apr 19, 2015 | 09:34 AM
pdqford's Avatar
pdqford
When its hot and cranking hard, how low does a volt meter across the battery terminals read?
BTW, both of your voltage drop readings are about double what they should be.
But with the same readings weather hot or cold, I can't explain why it cranks okay cold and not okay hot.
If I had a set of heavy jumper cables, I'd run one cable from the engine block to the B negative connection and one from the battery + terminal to the starter motor connection (effectively double up the existing battery cables) and see if that makes a difference.
Old Apr 19, 2015 | 04:48 PM
08f3506.8's Avatar
08f3506.8
With the truck hot, the battery dropped to 10v when cranking. I hooked up cables hot to starter, and ground to one of the bolts holding the starter on, and it made no difference
Old Apr 19, 2015 | 04:52 PM
08f3506.8's Avatar
08f3506.8
When under my truck I noticed the starter has a sticker that says rebuilt. And when you wiggle the positive cable, the stud into the selinoid moves as well
Old Apr 19, 2015 | 07:17 PM
pdqford's Avatar
pdqford
Can you tighten that stud?
Old Apr 20, 2015 | 10:42 AM
droldsmorland's Avatar
droldsmorland
Are these readings in amps, ohms or volts? What setting was the meter on?
Again did you pull and inspect ALL of the connections in the starting circuit?
Maybe we need to back up a bit and not eliminate the starter or battery. Are you sure you got a new starter? Take a look at it. Its not uncommon to get a bad new or reman unit out of the box. Same thing for a battery. Load test the battery hot. Does the 08 have a slave relay in line with the starter? If so look at it hot vs cold.
Load test the new starter. Which means removal and bench testing the amp draw.
Old Apr 20, 2015 | 04:19 PM
08f3506.8's Avatar
08f3506.8
I am reading volts on the meter. I talked to the ford dealership this morning. He wants the truck back so they can check the starter. I asked what the maximum allowable voltage drop is, and he said he would have to look Into it. I feel they are getting fed up with my truck because they can't figure it out, and are loosing money on it. The starter is stamped remanufactured
Old Apr 20, 2015 | 07:03 PM
pdqford's Avatar
pdqford
Typically, you want to see less than 0.2 volts dropped on the ground side and less that 0.5 volts dropped on the power side.
Does the positive battery pass near the exhaust pipe or exhaust manifold where the cable would get hot? Heat will increase the voltage drop.
Oh, wait! You said that the voltage drops were nearly identical between hot and cold starts.
Is there anything that they could have done that would put a drag on the engine when hot starting? A/C compressor hanging up? Or an Idler pulley seizing? Might try taking the belt off and try a hot start?
Old Apr 21, 2015 | 08:41 AM
droldsmorland
BINGO! we have a winner....This points to a bad starter AND the fact that you have a loose wire on the solenoid. The loose wire is likely the cause of the problem.
I just replaced a "brandie new" NAPA starter in a 99 7.3. The starter was totally locked up. It had about 2K miles on it. Had to hit it with a hammer on the bench with a D8 battery hooked to it just to get it to groan. Of course I couldn't get those dam philips head screws loose to pop off the solenoid for investigative purposes. philips heads really!
Metalhead47
Apr 21, 2014 01:09 PM
rideracelivemx7
May 25, 2009 06:15 PM
thomadm
Mar 10, 2007 09:38 PM
wiseguy50
May 9, 2006 11:11 AM
Zorburg
Jun 9, 2004 01:44 PM
