How far should the slave push?
Old Mar 30, 2015 | 03:01 PM
joegeds's Avatar
joegeds
96 F150 4.9L 4X4 M50D Manual trans with the concentric slave cylinder. I think I bled the clutch system OK. I closed up the system, and removed the rubber piece on the trans so I could see the slave. When the clutch pedal is pushed, the slave pushes forward and moves the fingers on the clutch cover plate about 1/2 inch. Is that adequate? What is the distance I need to see the slave push forward?
Old Mar 31, 2015 | 09:09 AM
joegeds's Avatar
joegeds
Just wanted to bump this from being buried on later pages to see if any of the morning posters might know. FTR, with the 1/2" movement of the slave, the clutch engages immediately upon beginning to lift my foot off of the pedal. In other words, I push pedal all the way down, shift, and the clutch engages that gear within the first inch or so of pedal release. This is first time out with new rebuilt trans, so maybe this is how it is supposed to react. I don't know.
Old Mar 31, 2015 | 11:07 AM
MtTheJeffro's Avatar
MtTheJeffro
Hi, I can't help a lot here as I've never watched the slave cylinder move as you described. Given the tight spaces in there, it should be acceptable. Main idea is that it engages and disengages the clutch disk properly. If that feels ok, I think you're set. Additional bleeding never hurts but I don't think it'll change much for you here.
Old Mar 31, 2015 | 11:51 AM
F150xlt's Avatar
F150xlt
Service manual says at least .53 inches.
Old Mar 31, 2015 | 03:02 PM
joegeds's Avatar
joegeds
It does? I looked in service manual and couldn't find it.
Old Mar 31, 2015 | 03:20 PM
88XLTLariat's Avatar
88XLTLariat
Just make sure you have fluid up to the fill line in your master cylinder. I was having the same problem with my truck clutch engaging immediately. I was very low on fluid. Topped it off and now it engages the clutch at about an inch or so from floor.
john.clark
13
Oct 12, 2015 03:14 PM
4601ton
Jan 5, 2013 08:55 PM
TwoMuchMud
Escape & Escape Hybrid
13
Sep 23, 2011 02:05 PM
Wild Karrde
Aug 13, 2007 10:05 AM
firemanbird
Aug 10, 2006 12:33 PM
