C6 to overdrive ?
Old Mar 30, 2015 | 11:21 AM
BigDan1's Avatar
BigDan1
C6 to overdrive ?
I have an 1988 Éconoline E-250 with a 351W & C6 ....
Any overdrive transmission that would fit without electronics ?...
thanks ,,
Dan ,
Old Mar 30, 2015 | 11:31 AM
Fishin76's Avatar
Fishin76
AOD would fit.. NOT an AOD-E.. (E for electronic) You may need new driveshafts though..
Old Mar 30, 2015 | 11:47 AM
BigDan1's Avatar
BigDan1
what year should I look for ?
thanks .....
Old Mar 30, 2015 | 12:16 PM
Fishin76's Avatar
Fishin76
thanks .....
IIRC, '80 to 90-91..
Old Mar 30, 2015 | 01:46 PM
BigDan1's Avatar
BigDan1
does the diesels 7.3 have the same bolt pattern then the 351 W ?
If not is there only the 302 & 351 W that are similar ?
want to know what to look for !
Thanks
Old Mar 30, 2015 | 04:32 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The diesels have a different bolt pattern. And the overdrive trans with the diesel is computer controlled.
The 300/302/351W share a bolt pattern. Anything else isn't going to work.
Old Mar 30, 2015 | 06:10 PM
85e150's Avatar
85e150
For the AOD, '88 to '93 are the preferred years. See post 4 here for more details:
https://www.ford-trucks.com/forums/1...ns-advise.html
Old Mar 31, 2015 | 06:37 AM
meborder's Avatar
meborder
IIRC, the best ones to find are out of the 91-93 F150 equipped with the 351 as they got the widest OD band available. everything else got a narrower band.
avoid transmissions that were behind v6's, unless you are going to go through everything to upgrade to the HD parts.
Old Apr 1, 2015 | 04:31 PM
andym's Avatar
andym
The AOD never came behind a 351, except in some crown vic's. Any truck with a 351w has a C6 or an E4OD.
Old Apr 1, 2015 | 04:36 PM
dustyroad's Avatar
dustyroad
yep and like I posted in his other thread about his van.
Putting a stock AOD in a e250 camper conversion is asking for it to melt down. But they don't want to read that. So they asked again.
Old Apr 1, 2015 | 06:40 PM
BigDan1's Avatar
BigDan1
Hola !
C6 to overdrive ,,,,,,where is the " they dont want to read that "
I`m asking ,because i want to put the one that could do it !
On what would i find a E4OD ? any year without electronic ?
dan
Old Apr 1, 2015 | 08:36 PM
Mark Kovalsky
All E4OD transmissions are computer controlled.
Old Apr 1, 2015 | 09:12 PM
BigDan1's Avatar
BigDan1
If there is no non computer controled overdrive tranny that fits on a 351W
what can I do then ?
Old Apr 1, 2015 | 10:18 PM
85e150's Avatar
85e150
If you simply must do it, consider this vs. an E4OD with a stand-alone controller:
Gear Vendors under/overdrive transmissions the most awarded auxiliary transmissions.
Old Apr 1, 2015 | 10:24 PM
BigDan1's Avatar
BigDan1
So I could install a E4OD but with a controler ...
any link ?
thanks
