5 volt pulsing DC, ICVR ???
Old Jul 25, 2003 | 12:30 PM
georgiaford67's Avatar
georgiaford67
I just purchased my 67 ford and have a couple of wiring issues related to the fuel and temp guages.
Is the dash ICVR the "silver can" with 2 wires?? One has 12 volts and the other (light blue) has 5 volts? The 5 volt side does not appear to pulse.
I have a 67 wiring diagram but very little seem to be matching up with what the diagram shows. Any input on this would be appreciated.
Thanks
Rich
Old Jul 25, 2003 | 07:14 PM
Mike W's Avatar
Mike W
It might be the meter you are using. As long as you have 5 volts you are ok. The purpose is to keep a constant voltage on the guages so the readings don't vary when the battery voltage does.
Old Jul 28, 2003 | 07:50 AM
georgiaford67
OK, I did locate the 5v pulsing circuits. What I found was the previous owner had the gas tank sending unit and the temp sending unit running to 12v. I ohmed out the tank sending unit and found that the wire windings inside were burnt up. I found a
71 model sending unit but the bolt pattern is a little different than on the 67. I was able to check with it though and it workes fine. Just need a unit to fit it at this point. On a good sending unit I was reading around 80 ohms.
The Temp sending unit is ohming completely closed, would this be right?? I checked from the Temp lead to gnd.. Sounds like it could be fried also.
Old Jul 28, 2003 | 09:34 AM
Mike W's Avatar
Mike W
Sounds like it is bad, I don't have the specs in front of me.
fmc400
18
Sep 9, 2024 09:03 AM
Gary Lewis
167
Sep 2, 2021 11:19 AM
dstraw
Nov 26, 2014 12:54 PM
Brnfree
Jul 28, 2013 09:07 PM
pjlandry
Electrical Systems/Wiring
Dec 24, 2006 12:47 PM
