overdrive stumble
Old Mar 30, 2015 | 08:24 AM
PowerLines's Avatar
PowerLines
overdrive stumble
So from what I have gathered online, it is an injector(s) issue. I've only had it happen to me twice at that speed but when I came to a stop afterward, my truck was barely idling.
I'm not sure if my sct programmer is able to show injector codes but it will show gp codes.
I guess my question is are failing injectors that intermittent typically? Also, has anyone had much luck with Rev X clearing that issue up?
Old Apr 1, 2015 | 07:46 PM
Rusty Axlerod's Avatar
Rusty Axlerod
If you haven't done the blue spring in the regulator or tested the FICM voltages I'd start there. There is detailed info for both in the Tech folder. RevX has helped some trucks, I'd say it's worth a shot as a third item but it's temporary if it does work.
Old Apr 2, 2015 | 12:14 AM
PowerLines's Avatar
PowerLines
I haven't done the blue spring yet....I keep hearing about it so I should probably get on the research.
I did test the FICM a couple months ago and it didn't drop below 46. I have a shop appointment next week for a diagnosis.
I got ahold of the local Rev x dealer and they are out for a couple weeks.
flysniper
Jan 25, 2018 04:11 PM
noj70
Dec 2, 2017 03:15 PM
Lubbockguy1979
Dec 13, 2016 01:09 PM
cabloom300
Jan 24, 2014 06:39 PM
bluesmanmike5
Sep 14, 2012 05:37 AM
