Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
2006 Escape Limited with Complex Electrical Issues
Old Mar 30, 2015 | 04:54 AM
bthorn's Avatar
bthorn
My 06 Escape with 165,000 miles has exhibited the following problems (In order of appearance)
1. Cruise Control failed while in-use several years ago.
2. Tire pressure monitoring failed at a later date- not one wheel at a time, but all at once
3. Driver's door cannot be opened using the remote fob or the external keypad, or the passenger side button, but it can be opened externally with the key, or internally using the door handle. BUT IT CAN BE LOCKED using the fob or any of the usual means
4. Recently, I had a situation where the battery was being drained rapidly. Pulling fuses, I found that the Smart Junction Box was the culprit. I found nothing wrong pulling the fuses that are on the Smart JB though. There was no fuse that stopped the drain when pulled. This issue still exists.
I'm not sure that the SJB can be blamed for all of these issues, but I'm convinced it is at least partially to blame for the drivers door lock. I don't understand where the radio frequency functions take place for the tire pressure monitoring and the key fobs. The Cruise could just be the unit itself.
Any ideas?
Old Mar 31, 2015 | 10:36 AM
tomw's Avatar
tomw
You likely don't want to spend the money to replace the SJB, but I think that is the culprit in your problems. There was a problem with water intrusion on the drivers side, near where a pedal-operated parking brake would be, coming from above. I would take a look at your fuse box backside for rust & other corrosion. The previous may apply more to GEM equipped vehicles.
The door lock is a flip-flop type thing. The + and - are reversed to perform the reverse operation. I think it is done with relays that operate to flip the + & - leads to the lock motor, or relays perform a switching operation like power window switches. If one set of contacts dies .. you lose that 'direction' of the lock. OR it could be internal switches part of the SJB.
The cruise may or may not be part of the condition, but you could check for VSS operation( Vehicle Speed Sensor - name to be changed on next whim from Dearborn) using a scan tool to see if the SJB is getting the signal...
Everything seems to point, in my thinking, to a SJB that is on vacation...
tom
Old Mar 31, 2015 | 11:49 AM
projectSHO89's Avatar
projectSHO89
The Escapes don't have GEMs or fuseboxes under the driver's side of the dash. Everything is done by the SBJ. No need to look for that as a 'possibility'.
jrsharp21
2009 - 2014 F150
Jul 2, 2018 10:54 AM
magnum136
Sep 15, 2017 09:41 PM
Lord Dark Star
General Automotive Discussion
Apr 4, 2016 10:03 PM
93f1505.0L
2004 - 2008 F150
Jul 3, 2008 07:51 AM
drewyzr1
Apr 1, 2008 04:14 PM
