Steering Column Shifter Lock
Old Mar 29, 2015 | 08:52 PM
PatOD's Avatar
PatOD
Hey guys I'm in the process of fixing up a 78 F150 farm truck, my first pre 90's vehicle, and the forums have been a great help; Is there a way to prevent the shifter on the steering column from being utilized while the truck ignition is off or without the brake being depressed? I would like to prevent people from screwing around and moving my truck easily(the lock is currently broken). So is there anything I can add to the column? I assume there wasn't a lockout feature in 79 like there is for all the cars today. Thanks in advance.
Old Mar 29, 2015 | 09:46 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
Just lock the doors...or is the door locks currently broken? Fix them... or get a ol style "club" and put on the steering wheel?? Yes they could still put it into neutral and roll it.
Bolt a short piece of chain or cable to the floor, using the forward seat track bolt, and then loop and chain it thru the steering wheel when parked. They might get the hint then?
NO you are correct there is not a "press the brake to unlock the shift column ability" option like new cars/trucks.
Where do you live to have people "screwing around and moving my truck easily" ? Some people would say put a firm "boot to ****/fist to face" to the 1st person you catch doing that to your truck. Sounds like some high school parking lot BS to me.
Disclaimer: I do not support or recommend violence. lol
Old Mar 29, 2015 | 09:57 PM
bkaul's Avatar
bkaul
Easiest thing might be to use something like a club so they can't steer it?
Or fixing the door locks is probably even cheaper than that...
Old Mar 30, 2015 | 12:51 AM
77&79F250's Avatar
77&79F250
Till they figure our you have vent wings that are not the locking kind.....butter knife will get a punk in with the doors locked.
Get some of these if you not not have locking wing levers.
Truck Parts and Truck Accessories
Slider lock bad... get some 1/4 bar stock steel rods and cut to length to fit in the groove the slider slider open in. Bend a 90 to have a handle to remove the rods easier.
Old Mar 30, 2015 | 12:58 AM
77&79F250's Avatar
77&79F250
Thinking about it more I guess you could take a piece of 4" long piece of pipe the same diameter as the column. Split it in half, hinge the one side, paddle lock tabs on the other and cut a notch so it slides over the shift lever. Then closes and locks???
Old Mar 30, 2015 | 09:17 AM
PatOD's Avatar
PatOD
Thanks all. The neighbors young kids got in the truck and were playing around, they had it in neutral and it rolled about 3 feet. They've been warned and I have parts for the lock coming. Just
Old Mar 30, 2015 | 09:56 AM
bkaul's Avatar
bkaul
In that case ... using your parking brake would help too, from a safety perspective.
Old Mar 30, 2015 | 10:14 AM
PatOD's Avatar
PatOD
That would be great if it worked haha, the mechanism is jammed; my project along with the door locks next weekend.
Olytlr
2009 - 2014 F150
Jul 14, 2015 08:28 AM
snakedoc
Aug 25, 2011 02:56 PM
darrin1999
Jan 29, 2007 01:18 AM
oldsmobileguy
1983 - 2012 Ranger & B-Series
Feb 2, 2004 11:16 AM
