'56 F100 Front Wheel Hub
Old 03-29-2015, 12:05 PM
Rusty_S's Avatar
Rusty_S
Rusty_S is offline
I wanted to ask did the F100 trucks in '56 used front wheel hubs from the cars as well?
I don't have a parts and illustration guide for the trucks to compare part numbers but I have heard that the early F100 were basically truck bodies set on car frames.
Old 03-30-2015, 11:45 PM
CharlieLed's Avatar
CharlieLed
CharlieLed is offline
Wow, I thought I'd heard it all...no, F100s are not built on a car frame. Ford/Mercury introduced the first independent front suspension in their car lines in 1949, the truck line kept the straight axle to 56 and beyond. I am not too familiar with the car hub/bolt pattern but I believe that the truck lug pattern is wider than the car as well.
Old 03-31-2015, 12:00 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,469 Likes on 1,408 Posts
Early Ford pickups before 1942 were built on car frames, and were even called 'commercial cars.' They were not F-100's or even rated at half ton like newer trucks. But Ford also built heavy pickups and larger trucks on their own truck chassis. Since 1942, Ford pickups all had their own chassis totally different from passenger cars.
1956 F-100 hubs were not the same as car hubs.
blueoval100
04-19-2015 10:00 PM
big-boss
03-14-2006 03:23 PM
luckypete
06-06-2005 10:55 PM
richard jobe
11-15-2004 05:50 AM
TinkerToy66
11-10-2002 10:57 PM
Quick Reply: '56 F100 Front Wheel Hub
