hubs
Old Nov 13, 2004 | 01:36 PM
richard jobe's Avatar
richard jobe
hubs
bought parts truck (ebay ) 1981 ford 150 has rear end 9 inch get this car h
ubs? 4 3/4 also on front is their a hub off a ford car that would fit on 50 f1?
mabee 4 1/2 space i measured i was going to use 9" rear and mags on rear and front came with parts truck thanks richard jobe
Old Nov 14, 2004 | 08:13 AM
GreatNorthWoods's Avatar
GreatNorthWoods
What???? Okay, you bought a parts truck with a 9 inch. After that I got lost...
Vern
Old Nov 14, 2004 | 09:20 AM
Christopher2's Avatar
Christopher2
Veteran: Navy
I think his 1981 parts truck has a car bolt pattern on the 9 inch rearend and car hubs or bolt pattern up front. He wants to know if there is a car hub that will fit a 1950 F1.The disk brake kit you buy for the front of the F1 uses a car hub. You actually name the bolt pattern and they supply it with the kit. There is an adapter that is put on the axle for spacing purposes.
Old Nov 14, 2004 | 12:35 PM
richard jobe
reply to great north woods
i bought 81 ford with small wheel pattern car front & back i was going to put reae end in my 50 f1 i was wondering what to do about front wheels parts
truck has got mag wheels good looking i would like to use all 4 of them
thanks for thr reply richard jobe
Old Nov 15, 2004 | 05:50 AM
GreatNorthWoods
Richard,
If you plan on keeping your original front suspension, you could convert to disc brakes like Chris suggested and use rotors with 5 on 4.5 pattern. If you want to update the front suspension, you could put a Volare suspension under it or even a T-bird or other Ford suspension graft. These options would also give you the 5 on 4.5 bolt pattern.
Vern
