sudden strange sound when starting
Old Mar 28, 2015 | 10:54 PM
CharlaineC's Avatar
CharlaineC
Ok so the other day I did my points, plugs and, condenser, but my question is suddenly I have a screeching noise almost like when you try to start a running truck. Other then that shes running so much better. What might be the cause? does anyone have an idea? dwell reads 30ish. plugs gaped at .035 at heat range 4. I need to recheck the points but I think that I have them at .017
Old Mar 29, 2015 | 08:57 AM
Rasputin53's Avatar
Rasputin53
The first things that come to mind are stuck starter, water pump getting tired, alternator bearings or a loose belt. Since you were inside the distributor, did you put any silicone grease on the cam on which the points ride? Also make sure the new condenser isn't rubbing against the rotor.
Old Mar 29, 2015 | 09:21 AM
orich's Avatar
orich
The first thing comes to mind is you did not reset the timing afterwards.
Any time you put in or adjust the points you must reset the ignition timing with a timing light.
It's to far advanced.
Orich
Old Mar 29, 2015 | 07:12 PM
CharlaineC's Avatar
CharlaineC
Thank you orich Ill do that
Old Mar 29, 2015 | 09:03 PM
orich's Avatar
orich
Remember to get the idle down 600-550 and remove and plug off the vacuum advance before adjusting the timing the Queeny
Orich
Old Mar 29, 2015 | 10:05 PM
CharlaineC's Avatar
CharlaineC
well checked the timing and its 10 degrees btdc. had a mechanic friend help me with it. I'm going to pull the starter and check it as well. as he thinks that there might be something wrong with the starter. also going to check the flex plate
Plug gap: 35
Point gap/dwell: .017, 26-32
10* BTDC automatic
Curb idle speed: 550 rpm, in Drive, wheels chocked, brake set, headlights on.
plugged vac advance hose at the distributor.
Old Mar 30, 2015 | 07:46 PM
Alex from GA's Avatar
Alex from GA
The dwell is the point gap or the point gap is the dwell. It's just a more accurate way to set the points. With a Pertronix you don't ever have to mess with that stuff again and the timing never changes.
Old Mar 31, 2015 | 02:12 PM
JEFFFAFA's Avatar
JEFFFAFA
As I recall you had to change the starter recently. Warranty that bad boy out!
Old Mar 31, 2015 | 02:43 PM
Turbo Dog's Avatar
Turbo Dog
If the screeching is coming from the starter area, then it is probably to tight up against the ring gear. (Noises are hard to diagnose over the internet)
Good luck
Old Mar 31, 2015 | 05:13 PM
CharlaineC's Avatar
CharlaineC
well Pulled the starter out and it turns out to be striped clean. the gear is screwed up I mean I scratched it with my finger its that cheap. feels almost like pewter. I'll post a photo later
Old Apr 1, 2015 | 06:26 AM
Rasputin53's Avatar
Rasputin53
I wish you well in your quest for a decent replacement part. I just went through three new discs for my 94 Explorer trying to find one that didn't bottom out on the backing plate when the retaining nut was seated. #@%&$! foreign parts...
Old Apr 1, 2015 | 02:09 PM
JEFFFAFA's Avatar
JEFFFAFA
I am assuming you mean rotors. Don't be afraid to try your local Ford Dealer. We have Motorcraft part numbers on brake rotors now. They are cheaper than regular brown box rotors. May not be exactly the same as the assembly line rotors but better than aftermarket.
The aftermarket world feeds on John Q Public automatically assuming dealers are more expensive.
GiggityBurns
May 7, 2018 06:41 PM
tobyw
4 Cylinder Engines
Aug 25, 2015 02:53 PM
Victor L
17
Feb 4, 2011 02:09 PM
ColonyPark
4 Cylinder Engines
24
Aug 1, 2006 08:55 PM
ujinmanning
Aug 19, 2004 12:43 PM
