Locked Doors
Old Mar 28, 2015 | 04:34 PM
WingingIt74's Avatar
WingingIt74
Locked Doors
Some how my boys locked the doors, how do you unlock them? Both handles are up and the outside key won't turn the handle.
Old Mar 28, 2015 | 05:01 PM
Jolly Roger Joe's Avatar
Jolly Roger Joe
I once did the same thing. Luckily, I don't yet have seals on the doors, and I was able to run a coat hanger up from the bottom to pull the door handle down. Otherwise, you'll probably have to push in the rear window to get in unless you want to break something.
FortyNiner's Avatar
FortyNiner
Are the doors closed?
Old Mar 28, 2015 | 05:33 PM
49f3dls's Avatar
49f3dls
Try the gas filler if stock. Sometimes you can get the rubber off and get a coat hanger thru to open it.
Old Mar 28, 2015 | 06:32 PM
FortyNiner's Avatar
FortyNiner
The handles don't move with the key as you unlock the door.
Old Mar 28, 2015 | 06:52 PM
Moe Craig's Avatar
Moe Craig
unlock the wing window and then you can unlock the door
Old Mar 29, 2015 | 07:54 AM
WingingIt74
Yes the doors are closed and the inside handles are locked. The key doesn't do anything, as it's a separate lock mech, I think.
Old Mar 29, 2015 | 08:08 AM
mtflat's Avatar
mtflat
I'm with Joe, least likely way to cause damage would be to carefully push the rear window in.
Old Mar 29, 2015 | 08:40 AM
EffieTrucker's Avatar
EffieTrucker
Phantom of the Phorum
That's what Doc had to do when his wife........I mean when he locked himself out on a road trip once. (Truckstock 2014 I think?)
Old Mar 29, 2015 | 02:50 PM
WingingIt74
My son pushed a little harder on the door handle and it opened.... it doesn't lock well any more...
Old Mar 29, 2015 | 03:17 PM
Jolly Roger Joe
So, now you have something else to fix...
Old Mar 29, 2015 | 03:18 PM
WingingIt74
I thought my old jeep was bad.... anyone have a pic of the mech?
Old Mar 29, 2015 | 03:28 PM
49fordv8f4's Avatar
49fordv8f4
IIRC the inner door handle should move back to the unlock position when you shut the door to keep you from being locked out of the truck. When the latches wear they won't always do that, so as they will allow you to be locked out.
Old Mar 29, 2015 | 03:35 PM
FortyNiner's Avatar
FortyNiner
Kudos to Bobby https://www.ford-trucks.com/forums/1...le-repair.html
Old Mar 29, 2015 | 05:58 PM
Doc's Avatar
Doc
Yep.....and Yep.
Built_Ford_Tough_757
Jan 26, 2016 12:59 PM
mshoemaker
25
May 3, 2011 11:58 AM
bimmerbill
2004 - 2008 F150
23
Aug 31, 2005 07:49 AM
anemptycokecan
Bronco II
Aug 16, 2004 11:27 PM
