Weatherstripping for 80-86 crewcab back doors?
Does anyone know of a place who sells the window channel stripping for the back doors? I would like to use the original doors but there is nothing left of the strips. If not I can use the newer sets of doors from the cab shell I plan on using. Thanks
For the outer and inner window sweep seals you can use the seals for front doors and just cut to size. Not sure on actual window channel weatherstrip, but it is installed in two pieces and cut at top front part of glass for the sharp 90*. I would order the seals for a front door, from looking at mine (with reasonably supple and intact weatherstrip) I'd say it should fit fine. Rear glass is same height as front but shorter length.
Thanks everbuddy
MUSKRATT2
15
12-12-2011 09:11 AM
