Electric choke issue
Old Mar 28, 2015 | 12:01 PM
AK FORD GUY's Avatar
AK FORD GUY
Over the last few days I have been trying to get my electric choke and high idle set and I am not sure if I am making this harder than it needs to be or not.
I was getting close to having it dialed in and now the it seems the electric choke does not open all the way and the idle does not drop down as it did a few days ago. I still need to do some investigating behind the choke cap and see if power is coming from the stator wire as it should.
I thought it a bit weird that it was an all of the sudden change though.
If everything looks to be in order behind the choke cap, I may power through a full 12v source and see if that works.
Please throw out any other ideas of things to check.
The set-up:
Stock reman 360
Edelbrock Performer 390 intake
QuickFuel carb (choke powered through stator wire of the 3G alternator)
Old Mar 28, 2015 | 01:30 PM
Pickupmanx2's Avatar
Pickupmanx2
Veteran: Marine Corps
#1 make sure it gets the full 12v,,, when I did mine, I left it outside, so Sat. morning I went out and loosened screws, turned choke housing until it was closed with just a tad more of a turn. Never had a problem since. BTW it was winter and about 25* outside. I would get in, punch it to floor once and turn the key, fired up EVERY time, idled about 1200-1400 for a min. or two, then I would give it a "punch" and it would idle down and be happy. Was on a 300 I6, Offenhauser intake and Holley 390cfm carb. My Edebrock 600cfm I did the same way on my 77 with 351Measly.
Old Mar 29, 2015 | 11:29 AM
ZarK-eh's Avatar
ZarK-eh
Careful with that 12 volts to electric choke business!
Some fords use the electric off the alternator stator which puts out 7-10 volts AC.
Not sure what happens if full 12 volts is applied to an oem choke designed for low voltage. Aftermarket chokes seem to use full 12 volts, so be sure with what you got before changing stuff!
Theory is that the choke is only powered if the engine is running. This way if the ignition is left on, the choke isn't doing anything and the engine will start properly.
Old Mar 29, 2015 | 12:44 PM
AK FORD GUY
Thanks, great advise both of you.
My carb is an aftermarket one and the instructions state 12v choke, I just figured I'd try the stator wire because it worked for others.
I won't have much time at all to work on the truck today, due to domestic duties...
Does anyone know which wire is live with a full 12v only when the engine is running?
Old Mar 29, 2015 | 12:46 PM
ZarK-eh's Avatar
ZarK-eh
Ah, that makes sense now.
I've heard of people using an oil pressure switch to apply power when the engine is running. But as far as I know, there isn't any circuit or wire that is on when the engine is running.
edit: I found these: http://www.colehersee.com/home/grid/cat/227/
Last edited by ZarK-eh; Mar 29, 2015 at 12:48 PM. Reason: add url for electric choke thingies
Old Mar 29, 2015 | 01:11 PM
AK FORD GUY
Not a bad idea!
Since I just wired an oil pressure switch for my fuel pump, I'll just tap into that wire.
Old Apr 7, 2015 | 12:16 AM
AK FORD GUY
The choke seems to work much better with a full 12 volts.
Kyle Wood
Jan 28, 2018 11:59 PM
JReagan90
Sep 13, 2011 06:14 PM
teamshadyinc
Jun 1, 2010 04:55 AM
$Simpleman76
Apr 22, 2007 11:46 PM
TMancil
Feb 9, 2002 12:04 PM
