Need some help from the best? 1979 f250 4x4 SnowFighter
I just purchased a 1980 f350 custom 2wd 400 with a 4 speed. It was used to haul draft horses all its life and only has 65000 miles. My question is can I take the 400 out of this truck as is, in stock form, emissions and all, and be able to put it in my 1979 snowfighter in place of its 351m? I can see the emissions are a different set up but I'm wonder how different? To me it looks like I could pull the motor out of my 79 and put this one in its place as is. I even think the the oil pans are the same.
Ford used feedback carburetors on some engines - these would have an ECU and an O2 sensor in the exhaust for feedback, and the thermactor air system would pump the air in at the cats rather than the exhaust ports. I don't know if they ever did it on the 400 or not, but even if so, you said you would take it "emissions and all" ... that's just part of what you'd swap.
You already have the truck, you said ... go look and see what it's got in it. Is there an O2 sensor? Is it a feedback carburetor or a straight mechanical one?
hornet258
05-16-2011 11:37 PM
