WTB 1978 Three spd trans
Old Mar 28, 2015 | 07:32 AM
gravydude's Avatar
gravydude
I'm asking here because the WTB area wouldn't let me post.
I have a 1978 F-150 300ci "Three on the tree" with a bad transmission.
Looking for a replacement trans.
I have a one piece drive shaft. I believe these tranny's were only in 78 to 85?
Cheers,
Joe
Old Mar 28, 2015 | 07:51 AM
gatorfor88's Avatar
gatorfor88
https://www.ford-trucks.com/forums/1...-79-parts.html
Old Mar 29, 2015 | 10:29 PM
Ozzie H.'s Avatar
Ozzie H.
Post
Cheers,
Joe
Hollander says that in 1978 the F-150 could have had one of four possible 3 speed manual transmissions. There were two different case lengths, each of which could have had two different extension lengths. The 9-1/4" case was called light duty, while the 9-3/4" case was called medium duty.
Old Mar 30, 2015 | 07:10 AM
gravydude's Avatar
gravydude
Dang! Good to know Ozzie.
Where do I measure this? Is this the length of the trans minus the bell-housing & tail shaft?
Cheers
Old Mar 30, 2015 | 08:13 AM
Shakes the Rat's Avatar
Shakes the Rat
I don't know where you are from but if you are close to south east Texas, I have the three speed I pulled from my 76. I pulled it to swap in a five speed. I normally make a run to the scrap yard once a month but I hate to junk good parts so this one is sitting around taking up space. If you can pick it up its yours.
Small block bellhousing
The codes on the tag are
RABAC DG29
D5TRLA7586
Old Mar 30, 2015 | 08:37 AM
Ozzie H.'s Avatar
Ozzie H.
Cheers
I am assuming that is correct. If you measure yours and it agrees with one of the numbers we will know for certain. If you also measure the tail shaft I can provide the interchanges shown.
Old Apr 3, 2015 | 07:51 PM
bmuhlbach's Avatar
bmuhlbach
I have one from a 68 F100 I am South of Cleveland.It is a slip yoke type.
Old Apr 3, 2015 | 10:31 PM
gfw1985's Avatar
gfw1985
Cranky Old Guy
You can usually find something close to you at: Car-Part.com--Used Auto Parts Market
Yahiko
Jan 18, 2015 01:10 PM
mrsvegan
Oct 10, 2013 09:58 AM
disoletruck
1997 - 2003 F150
Dec 5, 2008 06:32 AM
Beechnut
Aug 10, 2004 08:38 AM
busterhd
May 9, 2001 06:55 AM
