6.0 core value?
Old Mar 28, 2015 | 01:00 AM
brown89ford's Avatar
brown89ford
6.0 core value?
Trying to offload a 2004 6.0 core. What should I expect to get for it.
Good heads, #8 bearing spun. No accessories, HPOP, injectors or Turbo.
Trying to figure out if I priced it too high or the demand isn't there. If there is no demand I guess I'll hang on to it.
Old Mar 28, 2015 | 03:05 AM
Yahiko's Avatar
Yahiko
Without the injectors and turbo. You won't be able to give it away.
Anytime you strip an engine of major components like that they
loose a lot of any value that may of been there.
How do you know that the heads are good and that the bearing spun?
Sean
Old Mar 28, 2015 | 04:07 AM
dannyboy950's Avatar
dannyboy950
You need to keep in mind that a core return for most engine rebuilders you only get from $300. to $500. and that, only if it is rebuildable and is complete[missing no major components]
Aug 4, 2015 12:53 AM
dannyboy950
Nov 4, 2014 12:53 AM
schmidt64
Nov 10, 2012 08:13 PM
50th ann
1997 - 2003 F150
24
Nov 24, 2010 02:58 PM
bummy
1997 - 2003 F150
Nov 10, 2006 04:02 PM
