Boost Dynamics ??
Old Mar 27, 2015 | 03:44 PM
hydro man 17's Avatar
hydro man 17
Boost Dynamics ??
I know how the physical aspects of the turbo works, but have wondered why there needs to be load on the engine to produce boost. In neutral no load, engine RPM @ 3000 = no boost, even though exhaust gas is spinning the turbine/compressor. Same conditions pulling load = ~ 22 PSI.
Technical answers anyone??
Mike
Old Mar 27, 2015 | 04:44 PM
Rikster-7700's Avatar
Rikster-7700
I think it is because your engine uses more fuel to spin the engine to 3000 RPM when it is under load as opposed to being revved in neutral?
More fuel means more exhaust gas, which means more boost. Conversely, when you are revving in neutral, much less fuel is used, and there is much less exhaust gas to spin the turbo
At least that is how I understand this to be the reason.
Old Mar 27, 2015 | 10:45 PM
The Brad's Avatar
The Brad
^^^ There's your answer.
rob17
6.7L Power Stroke Diesel
Nov 22, 2016 11:59 PM
Rishsd
Apr 26, 2013 09:07 AM
dwilliamsceg
6.4L Power Stroke Diesel
Sep 23, 2010 07:38 PM
bakerbuilttracks
Oct 16, 2008 10:00 PM
Craze
Aug 23, 2005 12:27 PM
